Old 09-23-2012, 04:26 PM   #1
travz500
travz500's Avatar
Has anyone converted a 2 wheel drive to 4x4?
has anyone converted a 2 wheel drive to 4x4? If so did you use the original 2 wheel frame or find a donor? I dont like the look of putting on a newer frame but can find a 4x4 shortbed frame bought one today but mainly for the shackles since it had a hole rusted into frame and it had been shorted from a long bed not sure what i want to do now since cant find a frame that i need. any ideas??
travz500 is offline   Reply With Quote
Old 09-23-2012, 05:03 PM   #2
j.kirn
Re: Has anyone converted a 2 wheel drive to 4x4?
1 on e-bay right now
j.kirn is offline   Reply With Quote
Old 09-23-2012, 05:49 PM   #3
travz500
travz500's Avatar
what is it listed under?? I tried to find it and i cant find it is it just a frame?
Old 09-23-2012, 06:15 PM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I am in the process of converting my sub over (check the build threadV), using 88 sub 4x4 parts
Old 09-23-2012, 07:48 PM   #5
rcbildr
rcbildr's Avatar
I'm converting my 63 check to 4x4. I have a build thread in the 4x4 project forum. It might be a few pages back because u haven't posted/worked on the truck in a while.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 09-23-2012, 10:12 PM   #6
j.kirn
its under a 1965 or 1966 chevy truck
