Alright I have a 1986 Chevy k10 stepside that has a small issue. When my lights are on and I hit the brakes the drivers side tail light goes out completely.any other time I hit the brakes both brake lights work. How do I fix something like this? What causes this problem? Also I have no reverse lights either.
Posted via Mobile Device edit posted in the electrical sectionM Edit posted in the electrical section instead Last edited by yellow400ex05; 09-23-2012 at 08:03 PM. |
Re: Tail light goes out when brakes are applied?
Make sure you have a dual filliment bulb in place.check the grounds for the tail/brake lights.reverse is separate from everything else.sounds like a ground issue
Posted via Mobile Device |
I agree, check your grounds. That would be the first thing I would check.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
see thats the thing the only ground i know of is the one right behind the tail light, other than that i can't seem to follow where else the tail light is wired to or if there may be a ground on the frame somewhere.
Moderator
![]() Join Date: Oct 2008
You found the ground for everything but the plate lamps. This ground causes the symptoms you describe. Both my trucks have a wire to the frame with ring terminals soldered to both ends... installed by me.
Make sure the taillamps are 1157 dual filament bulbs. I've seen single filaments forced into the dual sockets.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
