Old 09-23-2012, 09:30 PM   #1
Steve Cole
Alternator clearance issues. Need ideas.
What are you guys with the tall valve covers on the 350 engines using for alternator mounts? Mine is mounted on the drivers side above the PS pump. The upper "adjustment arm" is attached at the water pump attach hole and isn't long enough anymore. There are no threaded holes in the heads or block to pick up for use and I'm not a fan of the low mounts or the 12 O'clock position mounts.
So, what is everyone using? Pics would be awesome!
Steve Cole is offline   Reply With Quote
Old 09-23-2012, 09:45 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Alternator clearance issues. Need ideas.
here is a pic of mine no power steering note the location of the alternator adjustment arm. I am using a 55 1/2 inch belt
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 09-23-2012, 09:54 PM   #3
GMCJOE
GMCJOE's Avatar
A lot of people go with the low mount alternator kit, but not being a fan kinda eliminates that option. Relocating to the other side of the engine may be a option with a different factory alternator bracket. I know the 10-SI is a thinner alternator. Not sure which one you are running.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 09-24-2012, 09:06 AM   #4
Steve Cole
Hey Hayhauler,
Beautiful engine! Unfortunately, I can't mount mine where your mount is located because the threaded holes are not there. If worse comes to worse, I may drill my own holes but that would be a last resort. Another style of mount is my preferred way to go.
Surely someone here has run into the same problem!
Old 09-24-2012, 09:16 AM   #5
rsmarr1982
rsmarr1982's Avatar
Originally Posted by Steve Cole View Post
Hey Hayhauler,
i would advise not drilling any holes. i had a machine shop do that once to a set of heads i had. the problem is where those holes are from the factory the casting of the head is raised . and i tried over and over again to shape washers to fit so that the bracket would be straight and it never worked right. if i got on it in a race or just even getting on the highway fast the belt came off.
1969 chevy c10 lwb stepside 250 6 3 ott
1971 chevy c10 lwb 250 6 with power steering 3 ott
1972 chevy k20 4x4 350/TH350 automatic
1978 chevy Malibu 4dr 305 2bbl (all original)
1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver)
rsmarr1982 is offline   Reply With Quote
Old 09-24-2012, 09:35 AM   #6
GMCJOE
GMCJOE's Avatar
I had issue with mounting mine, unfortunately I don't have pics of the swap up. I put a 96 LT1 engine in mine, and had no original equipment to use from the donor. And the holes don't match older equipment. Pretty much like having no holes. Ended up with the low mount kit.
I do not recommend drilling holes into a head, most likely drill into a water jacket or crack the head. Those heads sound like the was made for a race engine, requiring no additional equipment. Sell them and buy ones with holes.
You might be able to use a alternator bracket that mounts to the intake and water pump. I would suggest for the lower bracket, make your own. But you might still have clearance issues with the valve covers.
Here is a link to a set-up I am describing. http://67-72chevytrucks.com/vboard/s...d.php?t=342062
Joseph
Joe's 69 GMC
