Old 09-23-2012, 09:50 PM   #1
str8axle55
Cab mounts
I`m getting ready to do a body swap on my CC K30. All of the rubber mounts are junk, between 3 trucks I can salvage enough shells to do poly mounts. What are you guys running, stock rubber, most likely LMC kit, or poly mounts. I have a flatbed, so that isn`t an issue, just the cab/core support. Trying to do this on a budget for DD plow /work truck. LMC kit is like $220 complete w/bolts plus shipping. Poly is like $95 plus shipping, no shells, no bolts. Who is using poly, do you like them?
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 09-23-2012, 10:46 PM   #2
Pro Performance
Pro Performance's Avatar
Re: Cab mounts
There is a lot of debate on rubber vs. poly. I prefer poly, since I know it is going to last longer than the rubber and offer less flex. We sell Prothane, and haven't heard anything bad about squeaking, etc..... plus the black color bushings have a hint of graphite in them which help against squeak, if any existed at all.
Let me know if we can help you with a set. The prothane doesn't come with shells or bolts, as you will use factory bolts if still in good shape. They are however, cheaper than $95, and I stock them in black.
Travis
Pro Performance is offline   Reply With Quote
Old 09-28-2012, 07:46 PM   #3
str8axle55
Re: Cab mounts
Nobody else has an opinion, or can share some wisdom.
84 Chevy K30 CC SRW
Old 09-28-2012, 10:33 PM   #4
74 stepside
74 stepside's Avatar
Re: Cab mounts
I just bought polyurethane body mount bushings for my 74 standard cab from Summit. They were about $50. Less body flex than rubber. As for bolts you can reuse yours or just buy grade 8 bolts. I dont see spending $220 on a rubber kit. Way too much mark up on that kit.
74 stepside is offline   Reply With Quote
Old 09-28-2012, 11:25 PM   #5
dieseldawg142
dieseldawg142's Avatar
Re: Cab mounts
i too just bought poly mounts for my 85 crew, $75. i'm replacing my hardware w/grade 8-cheap & better then almost 30yr bolts. i've heard more noise comes into the cab than rubber, but i'll take the longevity. i'm running an 8" lift, & all susp. bushings are poly, much tighter & responsive than rubber
dieseldawg142 is offline   Reply With Quote
Old 09-28-2012, 11:35 PM   #6
frog210
Re: Cab mounts
i got mine from rockauto
there the black rubber ones
22 each
work prety good
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 12-01-2013, 09:43 AM   #7
doghousecustoms
Re: Cab mounts
Travis
im really intrested in your kit for my truck but i want one that includes the bed mounts and core support as well
thank you
doghousecustoms is offline   Reply With Quote
Old 12-01-2013, 10:32 AM   #8
Pro Performance
Re: Cab mounts
The body mount kit does include the core support mounts as well. The bed bolts directly to the frame without any bushings, so nothing is needed there. We have a 10% off right now on Prothane that ends today, and can be ordered right off our site at this price.
http://www.azproperformance.com/Prothane-67-72-C10/
-Travis
Old 12-01-2013, 08:03 PM   #9
79Betty
79Betty's Avatar
Re: Cab mounts
Since poly doesn't flex as much, won't that cause more stress on the supports and mounts this leading to cracking?
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 12-01-2013, 09:45 PM   #10
rs74
rs74's Avatar
Re: Cab mounts
I ended up buying the rubber LMC kit for my short bed. Haven't installed it yet but that is what I bought. What worried me about the poly kits was how much were they going to stiffen up the truck and also the possibility of squeeking. If I could have found someone locally that had the poly kit then I could have seen first hand. I always hate going out on a limb for something I know little about. I felt the rubber kits were a safe bet. JMO.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 12-02-2013, 09:10 AM   #11
Pro Performance
Re: Cab mounts
No, it won't cause the supports to crack, as they are very well mounted to the frame from the factory.
Old 12-02-2013, 09:38 AM   #12
Desert1957
Desert1957's Avatar
Re: Cab mounts
OEM style on my 87 lasted 25+ years, rides better then "Poly".
Why change? Do you think you will own your truck longer then 20 years?
Desert
Desert1957 is offline   Reply With Quote
Old 12-02-2013, 12:37 PM   #13
83GMCK2500
Re: Cab mounts
Desert
Agreed. Been gathering up full set of GM rubber mounts. Truck is 30, has needed them for the past 5 or so years. Have about 500,000 miles on them, they're due.
And yes, I'll be keeping this truck.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 12-02-2013, 11:41 PM   #14
king-918
king-918's Avatar
Re: Cab mounts
I went Prothane From Travis.
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 12-02-2013, 11:45 PM   #15
king-918
king-918's Avatar
Re: Cab mounts
Desert
I'm willing to bet you have needed them longer then you know. Like shocks they can have a slow decline. you the driver will not notice until completely worn.
<----Christopher
Oklahoma
Old 12-03-2013, 01:51 AM   #16
willett
Another Day, Another Dollar
willett's Avatar
Re: Cab mounts
I bought poly mounts. Energy suspension brand I believe. The ride is fine but they didn't come with any hardware
This was a problem as my 40 year old hardware was effed up! There are some metal bushing spacer thingies that I had to fabricate from pipe and big-ass washers.
There is more to the hardware than just bolts and washers, if you think yours will be heavily rusted then save the trouble and go for the LMC kit. I had a heck of a time
Finding the right sized pipe to weld to the washers.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 12-03-2013, 02:23 AM   #17
dieseldawg142
Re: Cab mounts
so true. my cups & hardware were in good shape, the rubber even looked good, till i placed it beside the new mount (red prothane) & seen how much shorter it was from wearing out.
wasn't the ride that made me do mine, it was body lines out of whack.
have had poly in just over a yr now, noise-no difference, ride-no difference (no ride with 38.5's anyways), squeeks-none. truck does feel like it's screwed to the frame if that means anything..
Old 12-03-2013, 02:32 AM   #18
king-918
king-918's Avatar
Re: Cab mounts
I feel you there I need to hardware for the core support and don"t have a clue besides salvage to get just those.
<----Christopher
Oklahoma
Old 12-03-2013, 04:51 AM   #19
willett
willett's Avatar
Re: Cab mounts
I think I still have some of the pipe laying around. I'll see if I can find it and ill pull measurements
I think it was 5/8 id and 3/4 od which pressed nice and tight into a 3/4 washer and then I tacked it in place. It ended up having very similar dimensions to the oem hardware
