09-23-2012, 10:04 PM | #1 |
Do 5" drop coils in rear really require c-notch???
So I'm about to order all my drop springs and spindles and what I would like to run is 4 1/2 in the front and 5 in the rear, I just don't want to c-notch it of I don't have too. Thanks anyone with this lift please send pics if you can..
Posted via Mobile Device |
09-23-2012, 11:24 PM | #2 |
A guy with a truck
Re: Do 5" drop coils in rear really require c-notch???
Generally not necessary with 5" coils, but you'll be close with a load. You will have a lot of rake with that drop combination, though...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
09-23-2012, 11:54 PM | #3 |
What do you mean by that? The back end is still going to be too high?
09-23-2012, 11:57 PM | #4 |
I am going with the McGaughys 2 1/2 drop spindles with 2" drop coils on the front and I want the back end to be pretty much level or about an inch higher. What should I do
09-23-2012, 11:59 PM | #5 |
You might want to be at 6" or 7" rear for even stance. That will require a notch.
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
09-24-2012, 12:09 AM | #6 |
Where can I find coils that size? I have a Brothers catalog and a LMC and they only go to 5"
09-24-2012, 12:20 AM | #7 |
What was I thinking?
Early classic enterprises has 6" coils.
I had a 72 with 3.5 in the front and 5 in the rear and it had around a inch rake. Posted via Mobile Device Posted via Mobile Device
Justin '68 C/10 Custom Long wide bed '78 GMC Sierra short wide Project: Second time around...'68 short wide http://67-72chevytrucks.com/vboard/s...d.php?t=423949 |
09-24-2012, 12:21 AM | #8 |
I also didn't run a c notch.
09-24-2012, 12:38 AM | #9 |
Ok thanks guys I just looked at early classics 4/6 kit I think I going to go with that. Thanks again for the help I'm a rookie on suspension.
09-24-2012, 12:44 AM | #10 |
I also had a shorter front tire. I don't think you can go wrong with ECE 4/6! Good luck! This was 3.5/5 with 275/60 rear and 245/60 front
09-24-2012, 11:48 AM | #11 |
A guy with a truck
Can't go wrong with the ECE 4/6. Good choice!
09-24-2012, 12:20 PM | #12 |
Here is a 4.5" front (2" coils with2.5" spindles) and 7" rear (5" coils and a 2" bock). I am undecided if I will change that to a 1" block. At this time I have a 1" rake. Need to get some miles on it and let it settle before I change anything. If I stay at this height a c notch is going in.
09-24-2012, 05:58 PM | #13 |
Thanks for the pics. I went ahead and ordered the 4/6 drop from early classics, looks like a nice kit. Thanks again
09-24-2012, 06:59 PM | #14 | |
Happy to be here
Your current set up can be potentially hazardous with scrubline concerns. The tall blocks and extra length on those u-bolts will put your rear suspension on the ground in the event of a blow out. Not a safe scenario at all.
09-24-2012, 11:59 PM | #15 | |
09-25-2012, 10:52 AM | #16 |
Just a car guy
5" springs on the rear of mine, and I have a couple inches of travel before it his my bumpstops. No way its hitting the frame. Mine is a 69 c10.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
10-13-2012, 04:26 PM | #17 |
GobbleStalker Calls
I have the same question I am just prepping the frame for paint now. I am putting in 5 inch rear coils and want to know now if I should c notch or not. I am building a show truck so the biggeast load it will see is a couple of lawn chairs and a cooler or 2.
Thoughts. Thanks Kevin
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino. Stay Tuned! 1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD! 09 GMC Sierra SLT All Terrain pkg. 2014 Jeep Wrangler Sahara unlimited. ( The wifes ride ) |
10-13-2012, 05:15 PM | #18 | |
Just a car guy
10-13-2012, 08:58 PM | #19 |
GobbleStalker Calls
Ok with a 5 inch drop do I need to move the axle back and how do I do that if needed?
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino. Stay Tuned! 1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD! 09 GMC Sierra SLT All Terrain pkg. 2014 Jeep Wrangler Sahara unlimited. ( The wifes ride ) Last edited by GobbleStalker; 10-13-2012 at 10:08 PM. |
10-13-2012, 09:11 PM | #20 | |
Just a car guy
If you meant move the axle back, no you don't have to. Posted via Mobile Device
10-13-2012, 10:08 PM | #21 |
GobbleStalker Calls
LOL Thanks yes I did mean back.
