front suspention
I have a 70 swb i replaced the upper,lower ball joints inter,outer tierods and upper control arm shaft kits. As im driving it feels like somthing is loose. I have checked averything to seeif i left anything loose. i didnt so i checked my rims even checking the wheel bearings to see if they are bad. does anyone have any idea what it could be?
"Your trucks fast! You must have been going 120 when I passed you." "Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay" If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties... |
Re: front suspention
Check the rest of the steering components that you didn't replace. Pitman arm, idler arm, steering gear box, and the rag joint on the steering column. I suggest you have someone rotate the steering wheel back and forth, with the truck off. While you look for the play in the steering. Sometimes you can adjust the play out of the steering gear box, if it is worn and cause the problem.
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
