Old 09-24-2012, 11:44 AM   #1
Moostifer
a fool with no money
Moostifer's Avatar
Ignition switch
I finally got around to replacing that annoying sticking ignition switch on the steering column yesterday.
disconnected battery, took off the aftermarket steering wheel/horn button, realized I needed a special compression tool to remove the steering lock plate, (fast forward to coming back from the local parts store with said part). Removed plate, removed the screws to the blinker assembly, removed the cylinder locking screw, pulled out old cylinder, inserted new one, reverse order assebled.
now the blinkers dont work and when you turn the key to start, nothing.
horn works, fuses are good...
before I tear back into it tonight, anything I need to be on the lookout for?
Thanks,
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 09-24-2012, 11:59 AM   #2
meter swinger
meter swinger's Avatar
Re: Ignition switch
I just did mine about a month ago, and by your description everthing sounds right. Have you started checking for voltage?
meter swinger is offline   Reply With Quote
Old 09-24-2012, 02:02 PM   #3
Moostifer
Moostifer's Avatar
Re: Ignition switch
didn't check voltage, as everything was working before. I just had to hold my tongue out just right and try to turn the key 7-8 times in order for the key to turn.
any possible way the rack/sector moved to where the cylinder wont ingage it?
anybody have a blownup diagram so i can see how it's all supposed to work?
Old 09-24-2012, 05:26 PM   #4
76Charlie
76Charlie's Avatar
Re: Ignition switch
When mine did that I just ran a switch into the ashtray box and made up a starter button
1976 GMC SIERRA CLASSIC CAMPER SPECIAL! 454 BIG BLOCK BABY!
76Charlie is offline   Reply With Quote
