Old 09-24-2012, 12:09 PM   #1
OJ1988
Just a car guy
OJ1988's Avatar
Rear Gear options
Looking to improve milage on my truck. It currently has the factory 3.73 rear gear set.
I would like to try and find a numericlly lower gear to swap in to help improve milage. Ideally, I would like to pull a complete rear out of another truck and swap it. There are a few 67-72 models in a local scrap yard. Before I go pulling covers, what other gear sets might I find installed in one of these trucks?
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 09-24-2012, 12:51 PM   #2
68Stepbed
68Stepbed's Avatar
Re: Rear Gear options
The only options for a 67-72 with a 12 bolt was 3.07, 3.73, and 4.11 gears. 73-up could be found with 3.4 but they won't bolt right in.
If you were closer, I'd be willing to trade my 3.07 for what you have now.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 09-24-2012, 01:15 PM   #3
Coley
Coley's Avatar
Smile Re: Rear Gear options
Ok, this should be pretty easy.
First, the 1/2 tons (V-8's) came stock with a 3:07 ratio. If there is/was an alternate rear end in the truck it would be listed (99%) on the SPID in the glovebox as an option.....ie: 3:73 or 4:11.
So if you find a truck in the boneyard that has the SPID in the glovebox....you should be able to determine if it was a V-8 truck and if it was optioned with something other than the stock 3:07.
Note: make sure the truck is the right years for your truck relative to the 6 bolt or 5 bolt lug style.
Good Luck
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 09-24-2012, 06:34 PM   #4
OJ1988
Just a car guy
OJ1988's Avatar
3.07 might help with milage a bit. Would like to get a wider rear, but then I'd be 5 lug right?
Was there a wider 6 lug?
1973 Vega Drag Car
1970 C20 tow rig
Old 09-24-2012, 09:26 PM   #5
Mike C
Mike C's Avatar
What size tire do you have in the back? The easiest thing to do is put a 31" tall tire on it. (265 75 15 currently on the back of my '69 short bed with 307 in it.) That helps a bunch. If you have 28" tall tire now that will take 10% more gear out of it. Making the 3.73 effectively a 3.36. And if you have 26" tall tire the gears will be effectively 3.07.
Obviously, this is an easily reverted swap so you can play around with it to find exactly what you like. 2.73 gears could be found in some 73-82 trucks with the 12 bolt which would drop it even more than the 3.07 but acceleration would be pathetic at best IMO.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Last edited by Mike C; 09-24-2012 at 09:26 PM. Reason: 15" rim not 16" I typoed originally
Old 09-24-2012, 09:39 PM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I piked this up last week for my BB . Its 3:08 Posi from a 71 and I'm replacing my 3:73's hoping to improve my gas mileage.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 09-25-2012, 09:02 AM   #7
OJ1988
Just a car guy
OJ1988's Avatar
Good find!
AS to the tires, I am runing brand new 235/60/17's in all four corners, would rather not change them at this time.
I am running a wide ratio muncie, so I think acceleration will still be ok with a 3.07 rear. I'll have to see what I can find in the scrapyard.
1973 Vega Drag Car
1970 C20 tow rig
Old 09-25-2012, 09:34 AM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Wait a minute.Big question is ,where is that info from.To the best of my knowledge(questionable at best)
Auto came with 3:08-07
manual came with 3:73
Options were different for different wight ratings.
If you want better milage and are running an auto trans,I would suggest looking at the 700R4 or one of the electronic OD's.
For a standard,the 5-6 speeds would be a good choice.
The auto OD with a 3:73 seems to be the choice most prefer.This keeps your low end "grunt" while letting the rpms stay down on the hiway.
As stated above,the tire size can give you quite a bit of adjustment.
The real question is "What are you starting out with?"
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-25-2012, 09:56 AM   #9
OJ1988
Just a car guy
OJ1988's Avatar
As stated in my first post, I am starting out with a 3.73.
Looking at gears for a cheap option to improve milage.
A 5 or 6 speed would be cool, but spending $2000 to save a couple bucks on gas is not the best option imo.
I am looking at small things to improve milage.
1973 Vega Drag Car
1970 C20 tow rig
Old 09-25-2012, 11:56 AM   #10
Already Gone
Thats why I am going to a 3:08 instead of an ideal 700R4, cause its a lot cheaper to swap the rear end than a trans.
Old 09-25-2012, 01:12 PM   #11
68Stepbed
68Stepbed's Avatar
Since you're running a Muncie, I'd just install 3.42 gears. The 3.07(3.08) will be a bit of a dog with the 4-speed, especially on any incline. When my dad built his 56, he put in an M20 Muncie and a Ford 9" from a T-bird with 3.00 gears. It did ok on flat surfaces, but he almost burnt the clutch up pulling onto an alignment lift, so he switched to 3.70 gears.
The 3.73s in your truck now are actually the ideal gear for a manual trans, but if you really want to better your rpm range, I would go no higher than 3.42. This means you most likely won't find a ready to swap in rear. You will be better off changing just the ring and pinion set.
Matt
Old 09-25-2012, 04:24 PM   #12
67chevemall
67chevemall's Avatar
I have a ring and pinion and carrier in a box that are 3:07's,,,drop right in...
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 09-25-2012, 07:29 PM   #13
OJ1988
Just a car guy
OJ1988's Avatar
It pulls pretty hard with the 3.73 and Muncie. I go through the gears pretty quick when driving. I'm sure 3.07s would slow it down some, but I think I'd be ok. It's not my hot rod anyway.
Im gonna look around. Not wanting to swap just ring and pinion now, I'd like to put a posi in ot if I had it apart. But that's more cash.
Right now I want to fine tune it and get some more mpg's.
There's a place selling a 4th gear overdrive gear set god the munice, that might be cool, but a lot of cash too.
1973 Vega Drag Car
1970 C20 tow rig
