Old 09-24-2012, 12:19 PM   #1
77c10
77c10's Avatar
Tach question
1977 C10, GEN II LT1-350, TH350 trans, 3:08 gears. 295/50/20 rear tires. At 75mph ( per my GPS) my tach shows 3900 RPM. I really don't think this is correct. Any ideas?
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 09-24-2012, 12:59 PM   #2
i8tokyo
Re: Tach question
You sure about your gear ratio? AT that RPM you would normally have a 4:88. If everything is as you say, then your tach has gone south or you're stuck in second gear.
1982 C-20, 454, TH-400, PS, A/C, 71,000 miles
1978 C-20, 350, TH-400, PS, Non-A/C, 112,000 miles
If it ain't broke, there is still probably room for improvement.
Speed costs money, how fast do you want to go?
i8tokyo is offline   Reply With Quote
Old 09-24-2012, 01:09 PM   #3
77c10
77c10's Avatar
Re: Tach question
I am positive about the gear, took the cover off and counted the teeth myself. Also, I know it is in 3rd gear, so I am guessing my tach if off. Autometer says you can calibrate them and they are sending me instructions on how to do it. Now I have to come up with something to compare it to so I can calibrate it. Might be cheaper and easier just to get a new tach...
Old 09-24-2012, 08:29 PM   #4
bilfman
bilfman's Avatar
Re: Tach question
I had exactly the same issue and posted in these forums for help so I can't take full credit for this. But I did follow this link and presto all fixed!!
http://howtoalmanac.com/kevin/projec...chfixtruck.htm
I just follow the proceedure and all was fixed.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 09-24-2012, 09:43 PM   #5
77c10
77c10's Avatar
Re: Tach question
Thanks for the info, bilfman. I have an Autometer tach so this will not work forme. I appreciate the effort though!
Old 09-24-2012, 09:51 PM   #6
76stepsidechevy
Re: Tach question
Dumb question but is it set to 8cyl mode?
76stepsidechevy is offline   Reply With Quote
Old 09-25-2012, 03:36 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Tach question
was wondering about the setup too for 8 cyl
if you cut those little loop wires it makes it for 4 or 6
orange/brown
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
