![]() Join Date: Sep 2012
New to Site !!!
Hello everyone , Have a question or two ... First I want to say , this forum is great !!!
I have read a lot of post and learned a lot in the past week ... I also want to say I am not a typist or a good speller , so please forgive my grammar .. I have just bought a 72 GMC 4x4 K1500 a few weeks ago, almost back together from a restoration... Actually I dont know wat to call it , maybe a clone ? It is a 72 GMC title but the po had put a 68 chevy front clip on it and a chevy tailgate .. My question is, the hood is not lineing up with fenders ... ( Have pic attached ) does someone have a suggestion on how and if I can fix this ? I am thinking remounting the hood hinges lower and a lttle forward ??? |
![]() Join Date: May 2011
Re: New to Site !!!
Welcome to the board!
Take a look here on how to properly align your body panels. http://67-72chevytrucks.com/vboard/s...=318544&page=6
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: New to Site !!!
Looks like the cowl panel needs to be moved towards the windshield.
Member
Re: New to Site !!!
Welcome to the forum, and unfortunately cowl hoods do not fit near as good as they should considering what they cost. But, follow the advice on the link above and you'll get it a whole lot closer than that. Good luck
1970 CST LB Fleetside, 402 BB, PS, PB,AC 1968 Firebird 400 conv. 1965 Chris Craft 17' wood ski boat (SN #0001) |
Re: New to Site !!!
Pretty sure the fenders are on right , the cowl is off a little , already shimmed passenger side up half inch ... I think the main problem is the 72 GMC cab does
not accept the 68 chevy parts ... plus the cowl hood is way off ... the hood seems to have a lot more arch to it than the fenders ... I am not a body man but the eyes dont lie ... You say the hoods dont match up very well anyway ? Do the non cowl repro hoods match up ? |
Re: New to Site !!!
If it were me, and its not, I would take it to the body shop and see if they could fix it for me after I messed with the alignment for a day or two and couldnt get it right.
Florida Edition
![]() ![]() Join Date: Oct 2010
Re: New to Site !!!
Welcome from Central Florida. Nice looking truck. Take the hinges and latch setup completely off then lay the hood in place, you will know then wheather its worth fooling with this hood or not. I personally doubt it but at least you'll know which direction to go.
Good luck.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Re: New to Site !!!
Just my 2 cents, but before I went any further adjusting, I'd put a couple of layers of painters tape on the edges so you don't get any chips while your adjusting.
Also I'm not sure because I've never put this generation truck together from scratch before, but from having the same sort of issues from aftermarket hoods on 69 Camaros and early novas I can tell you that there is a lot of adjustment to be had in the cowl and fenders also. In my limited experience they usually need to be adjusted as a whole. I always stared at the back of th door and worked my forward. It has always been a pain in rear end for me. That said, maybe take it to a shop? Posted via Mobile Device |
Re: New to Site !!!
I thank you guys for the info and insight . I will continue to play with it a while
and if I can not get it , I will take the advice to let a pro body man look at it ... I will let you know the results ... |
