Old 09-24-2012, 12:49 PM   #1
dkauffman05
dkauffman05's Avatar
67, remove tuneport install 5.3
Got a new project at the shop . It's a nice 67 with a camaro tuneport that has a pretty bad wiring install. So I'm removing and replacing with a 5.3 .
The motor when I got it home.
Motor washed up getting ready for paint
Removed all unwanted wiring from harness getting ready to rerout for a cleaner look exiting behind the intake
dkauffman05 is offline   Reply With Quote
Old 09-24-2012, 01:53 PM   #2
67cheby
67cheby
67cheby's Avatar
Re: 67, remove tuneport install 5.3
great looking truck
67cheby is offline   Reply With Quote
Old 09-27-2012, 09:28 PM   #3
Parker086
looks good
Parker086 is offline   Reply With Quote
Old 09-27-2012, 09:29 PM   #4
Parker086
Need to lower it more!!!!!
Old 09-29-2012, 08:11 PM   #5
dkauffman05
Got some work do today
Took a while to get the mounts to work with stock a/c. Had to notch the compressor bracket in order to move the mounts forward enough to clear the headers. Eventually I got everything bolted up and marked the frame for some small clearance issues.
I then removed everything to focus on engine bay cleanup before final install. Then on to some major wiring issues
Old 09-30-2012, 05:46 PM   #6
Jdubs71
Jdubs71's Avatar
Looking good. How do you like that column? I was kind of thinking of going that route if it wasn't too much trouble.
Jdubs71 is offline   Reply With Quote
Old 10-01-2012, 08:54 AM   #7
dkauffman05
I don't know bout the column. I have driven the truck about 30 yards into my shop. It's noty truck I'm doin the swap for someone. He's a new member here name is parker086.
Old 10-06-2012, 10:54 AM   #8
dkauffman05
Pic from when I was getting engine bay ready for paint. It's painted now just don't have a picture yet. Motor should be going back in tonight for final install and wiring.
Old 10-11-2012, 08:22 AM   #9
etindoll
Good gracious that is a lot of wiring in the dash.
etindoll is offline   Reply With Quote
Old 10-13-2012, 08:26 PM   #10
dkauffman05
Getting close just need to button up few loose ends but you know how that is, forgot this forgot that.
Wiring routed into cab behind cluster where PCM relays and fuse block are located.
The view from my shop tonight. Had to take some time from wiring and put a cam in my truck.
Old 10-14-2012, 01:50 PM   #11
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Lookin' great Dan!! I'm tuned in.
Alan's Classic is offline   Reply With Quote
Old 12-04-2012, 10:36 PM   #12
cjohnson6772
cjohnson6772's Avatar
Very cool progress and an awesome install. I'm putting a LQ4 in a '72. Any chance you have pictures of the modified a/c bracket? Any pics of the driver side header clearancing? Are those stock v8 engine towers?
cjohnson6772 is offline   Reply With Quote
