Old 09-24-2012, 04:34 PM   #1
powerT
Chevy 4x4 ball joints HELP
1986 chevy K-10 4x4
Bougt truck a few weeks ago i took it to get front end alinement while in the they said the ball joints needed to be replaced. While changing the ball joints he found a hair line crack in the knockle part of the spindle. He said he was going to use a ball joint problem slover to fix it . What is a ball joint problem slover and how will that fix the knockle ???
powerT is offline   Reply With Quote
Old 09-24-2012, 09:20 PM   #2
powerT
Re: Chevy 4x4 ball joints HELP
Bump
Old 09-24-2012, 10:08 PM   #3
86c20
86c20's Avatar
umm the only thing i no of is some guys drill and tap them and then plug them grind them flush if need but that is just in a pinch. i would swap the knuckle
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 09-25-2012, 04:56 AM   #4
powerT
we are having a hard time finding a knuckle tried a few junkyards with no luck
Old 09-25-2012, 01:16 PM   #5
88Jimmy4x4
88Jimmy4x4's Avatar
dang...I think I threw a set of knuckles away a month ago, I will double check tonight when I get home
become a member on www.coloradok5.com, those guys swap out the 6 lug axles all the time for 8 lugs and sell the parts for the 6 luggers dirt cheap...probably get a set shipped for $50 from them
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 09-26-2012, 08:50 AM   #6
OLDCHEV4X4
OLDCHEV4X4's Avatar
Those 10 bolt front axles are every where around here. K5, K10, K20, Chevy, GMC. Keep looking, you should find one. Hit craigs list, I see people selling whole axles. Take what you need and sell the rest or keep it around for spares.
Never heard of a ball joint problem solver.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 09-26-2012, 11:20 AM   #7
Ski-me
Ski-me's Avatar
I've never heard of a ball joint problem solver either......
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
