Old 05-28-2003, 11:01 AM   #1
Low Truck FNG
Question Door Adjustment
My driver side door doesn't close very well. Kind of a loud clunk. Any adjustment advice?
Brian
'86 C10 Silverado, 350/700
Low Truck FNG is offline   Reply With Quote
Old 05-28-2003, 11:02 AM   #2
Low Truck FNG
Oh yeah, It's an 86 C10. I should probably put that in my signature block.
Brian
Old 05-28-2003, 11:43 AM   #3
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
First off, go buy a hinge pin and bushing kit from the auto parts store for the upper and lower hinges. The hinges wearing out on these trucks is so common, they will have the kits on the shelf. Take the door off paying attention to how it is adjusted now and install the new pins and bushings. Put the door back on and it will be very close if not exact with the hinges where they started.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 05-28-2003, 12:10 PM   #4
ocbaud
Garage Queen Material
i'm gonna be replacing my hinges and striker bolts VERY soon. my drivers side door sounds like its about to fall off, and my lower hinge pin keeps working its way loose.
ocbaud is offline   Reply With Quote
Old 05-28-2003, 12:17 PM   #5
ol84
Brian,
I had the same problem with my door. I replaced the Hinge Pins and bushings like Joe said and it took care of the problem. Striker bolts would be a good idea also....they are hard to get out, atleast mine were.
1984 C10 SWB
Custom Frame
Blow Through Carb Single Turbo
Hope to be on the road by Summer 2018
1967 C10 CST LWB
327/PG Original
Running Driving Future Project
ol84 is offline   Reply With Quote
Old 05-28-2003, 12:21 PM   #6
ocbaud
Originally posted by ol84
Brian,
all you have to do on my truck is get to the nut, which is behind the rear speakers, which i dont have anymore
Old 05-28-2003, 12:23 PM   #7
ol84
LOL, that would explain why I gave up on the task...duh
1984 C10 SWB
Custom Frame
1967 C10 CST LWB
327/PG Original
Old 05-28-2003, 12:31 PM   #8
ocbaud
yeap, my door is rattling like a mofo recently.
Old 05-28-2003, 03:10 PM   #9
PHOENIX
I can tell just by looking that my striker bolt has had its day. I went to GM dealer to get some other things and asked about the striker bolts. They were something like $20+ each. I passed of course. Is that why it is so hard to shut my doors?
I seriously have to slam them to get them to close all the way. The rubber is ok in the truck, but not great. Does my door slamming problem sound like the striker bolt? My striker bolt (the part that is striked) isnt even round anymore, it is flattened where the latch hits. The door doesnt rattle or anything if slammed. I have adjusted them in the past and it didnt make much difference. Im going to buy some soon and through them on, just hoping maybe someone had the same problem and this was the cause. If not what else could it be? My door seems harder to shut then other 73-87 trucks.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 05-28-2003, 03:57 PM   #10
ElGracho
ElGracho's Avatar
The cause is your worn out door hinges. That makes the door sag in the back and the latch mechanism is hitting (as has worn out) the striker bolt. The door hits that bolt and has to move up probably a half inch before it can close all the way, that's why it is hard to close. Replace the strike bolt (also available through Dorman at your local Autozone or whatever) and the door hinge kits, you'll be amazed at the difference.
Joe
Old 05-28-2003, 04:00 PM   #11
ol84
Word...word
1984 C10 SWB
Custom Frame
1967 C10 CST LWB
327/PG Original
Old 05-28-2003, 04:07 PM   #12
PHOENIX
Are you sure? Because when I close the door slowly and look the latch is lined up just right. Doesn't look off at all. I will look again to make sure.
Old 05-29-2003, 11:14 PM   #13
gmcbob
gmcbob's Avatar
I hope you guys have better luck than I did -
I purchased the hinge kits from gm, which included a two new bushings and a new hinge pin for each hinge. Took the door off, and the hinges off, disassemblemed them, and put in the new hinge pins.
About a week after I re-installed them and re-hung the door, the hinge pins kept popping up causing the door to sag. Every day I would have to push the pins back down to get the door to close correctly. I even spot welded the pins in, but they wouldn't hold every long before poppoig up again.
I can't imagine that I did anything wrong during the replacement & installation, but it obviously didn't work.
I ended up purchasing two new complete hinges from gm & replacing them. Had to pull the fender, and it was a ton of work & I was pissed at how long it took, bet now that it's over I'm extremely happy with the results. I can gently close the door and it closes perfectly.
Hope this helps.
Bob
Bob
1978 GMC Sierra Classic K15 Shortbed, 350/350/NP203, 31's on Rally's, Restored to Stock Condition. Two-tone Russett Metallic / Buckskin.
1987 GMC Sierra Classic V1500, Longbed, 350 TBI, NP205, 33’s on Chrome Spoke with 4” Suspension Lift. Black.
2014 GMC 2500HD 4x4 Duramax Crewcab
gmcbob is offline   Reply With Quote
Old 05-30-2003, 11:31 AM   #14
Low Truck FNG
Bob is scaring me!!!
Brian
Old 05-30-2003, 04:04 PM   #15
TIMSPEED
TIMSPEED's Avatar
I 2nd Bob's ideas. I bought that hinge kit from GM too..repalced the bushings and pins..stupid pins pop right back up a week after being pushed back down. So..anyone who rides in my truck..I tell em "SLAM and LOCK the door, or you might fall out."
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 05-30-2003, 04:11 PM   #16
solidaxel
solidaxel's Avatar
Mine did the same thing so I welded the pins in, only one pin would pop up, but the passenger door still is a ***** to close. I don't liking slaming doors especially on a well built truck, but if not you have to close it three times !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-31-2003, 06:15 PM   #17
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
My problem was the junk generic door shell that I installed to replace the rusted one that came on my truck. Even after rebuilding the hinges and replacing the striker it still needed to be slammed shut. From the window down it lined up perfectly with the cab and fender, but from the window up it appears to be pushed in too far.
I recently found a nice original GM rust free shell to install to replace the generic one. I hope this solves the problem.
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
Old 06-01-2003, 08:44 AM   #18
Moody Blue
I am having the same problem with my door, But after reading the reply's, I thing ill weld my doors up and enter through the rear window :p
mail me if your in or around Detroit, I need help with parts for my choke
Moody Blue is offline   Reply With Quote
Old 06-01-2003, 09:45 AM   #19
82 Silverado 4X
Genuine Chevrolet
If you have installed new door rubber it sometimes makes your door difficult to close properly untilit gets seated in.
George
Old 06-01-2003, 01:13 PM   #20
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
it may be just as easy to get a set of donor hinges i got mine from a junkyard for both sides for $15....and they didnt need bushings
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
