09-24-2012, 06:00 PM | #1 |
sag 4 speed
hey guys i got a saginaw 4 speed i put in my truck ! for some reason it keeps leeking gear oil out of the front behind the flywheel! im positive its not the rear main leaking oil cause i just replaced it! plus its been leaking before that! any ideas is there a front seal?
09-24-2012, 06:58 PM | #2 |
Re: sag 4 speed
There should be a input shaft seal pressed into the front bearing retainer. And a gasket for the front bearing retainer. Should be just 4 bolts holding it on. When you pull it off make note if there is a weep hole or a channel and where it's oriented, they usually go down to allow gear oil to drain back into the case.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
09-24-2012, 08:24 PM | #3 |
Re: sag 4 speed
While you got it apart replace the clutch. With a rear main and a snout seal leaking your disc is likely toast or close to it.
