My Carbon Footprint
Can I see your heater core and box delete firewall??
Really thinking of sheet canning the God aweful heater core and box from my engine compartment when I pull the motor and front end off my truck this winter. I have about 1/4" of clearance from my valve cover to that box. The heater hasn't been working for 5 years now. I have a bunch of aluminum sheets and was thinking of making a nice cover but can't remember how big the opening was. Thanks guys!
PS: I'm thinking of just leaving the box inside the cab as is. I'm guessing that just doesn't look right when removed, but if you can prove me wrong, I'd love to see pics of what you did on the inside too! |
Re: Can I see your heater core and box delete firewall??
![]() Used some aluminium plate then filled and faired.Cardboard template worked fine.I did not weld{dont have 1 or the knowhow}but I used duraglass to fill and fair. |
stainless steel
Fuzzy |
Wide n'Low
![]() Join Date: Jan 2007
I'm sure you will get a quicker response, as I just pulled all the cab components on my son's cab. I will measure out a template tonight. I am hoping to install a Mojave heater with a plenum and re-use the stock defrost and a/c vents for heat. I am curious as well how it will look without that big black box hanging below the dash.
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
#5 | |
I used filler panels. Here's a few pics. Hey...where's Ricky Bobby?
My Carbon Footprint
I mix it up from time to time. Nice work Randy!!
Here's a few shots of mine, I bought the filler panels from Infanti Rides.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
My Carbon Footprint
Hey Randy.....what in the heck are those ratchet straps hooked to?
Keep Your Nose Clean
Heres mine. i deleted the heater core, added a piece, and covered the gutter.
