Old 09-25-2012, 11:38 AM   #1
cubber
control arm question
I have a 69 C10 I am bagging. It has72 disc brake spindles. I found a good deal on some 84 model lca's that have been cupped. Will these work with my same upper arms, or do you have to switch both?
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 09-25-2012, 08:00 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: control arm question
They will work,... and the '84 lower balljoint will even work with your 71-72 spindles.
However, you will need to change the '69 upper ball joint to a 71-72 balljoint.
Keith
Convert to disc brakes.
Old 09-25-2012, 09:16 PM   #3
cubber
Thanks, Lolife! I was thinking you might know from reading your other posts. I have already replaced all the ball joints, and ran into the slight confusion of the ball joints being different. I have already rebuilt all the suspension and steering on the truck, driven it less than 500 mi, and have decided to chage my brand new CPP drop springs for air bags. Thanks so much for your help. BTW, are the cross shafts and bushings interchangeable?
=MATTHEW
Old 09-25-2012, 09:43 PM   #4
cubber
Dang! He sold em last Friday. Anyway, good idea, though.
=MATTHEW
Old 09-25-2012, 09:53 PM   #5
lolife99
lolife99's Avatar
No.
67-72 a-arms have steel bushings.
73-87 a-arms have rubber bushings.
Keith
