Old 09-25-2012, 02:04 PM   #1
GMC66
GMC66's Avatar
Power brake Vacuum
Gentlemen, I recently swapped my truck over to power brakes. I've tried both the vacuum on the intake just below the carb and the PCV vacuum. Both seem to make the truck run rough. I've adjusted the carb multiple times, can't get rid of the miss at idle and low RPMs with the vacuum hooked up to the booster. If I remove it, it runs like a top, perfrctly. Any advice? Thanks.
GMC66 is offline   Reply With Quote
Old 09-25-2012, 02:30 PM   #2
padresag
Re: Power brake Vacuum
a vacuum leak in the booster- bad diaphram
ron
padresag is offline   Reply With Quote
Old 09-25-2012, 04:39 PM   #3
ChuckW
ChuckW's Avatar
Agree with padresag. How does it run if you plug the vacuum line at the booster?
ChuckW is offline   Reply With Quote
Old 09-25-2012, 04:45 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Also check the hose to the booster and the nylon inlet valve for cracks or damage. If the engine only runs rough when the booster is connected the problem is right there. Either the booster or the connections. If there are no leaks you shouldn't be able to detect any difference in engine smoothness.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 09-25-2012, 05:00 PM   #5
GMC66
GMC66's Avatar
Truck runs great if I remove booster vacuum. The booster is brand new from performance online. I will check the diaphram
Old 09-25-2012, 05:18 PM   #6
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Hook the hose up and suck on it.. Funny yes but if it cannot hold the small amount your lungs can pull then its no good.. A small mighty vac would work better, but hey what works is all that counts.
GMR-PERFORMANCE is offline   Reply With Quote
Old 09-25-2012, 06:48 PM   #7
MARTYZ
MARTYZ's Avatar
If you pull the hose fitting out of the booster after the engine is shut off for a couple of minutes there should vacum in the booster, if not the booster is leaking or the check valve in the fitting is faulty.
MARTYZ is offline   Reply With Quote
Old 09-26-2012, 05:49 PM   #8
GMC66
GMC66's Avatar
When I suck on the hose, its like sucking through a straw...so bad diaphram? Weird, it's brand new. Time to call POL. Thanks guys.
Old 09-26-2012, 05:56 PM   #9
GMR-PERFORMANCE
Well I heard a nice name for POL not too long ago and it was not very flattering.. I find that many times if you can get it local its better even if the price is a tad more as its easy to get it swapped out.
Old 09-26-2012, 08:39 PM   #10
padresag
made in china?
ron
Old 09-27-2012, 01:57 PM   #11
Hx16457
Hx16457's Avatar
I have found out the hard way, as well "NEW" doesn't mean "WORKS", victim of Power Steering pump.... wonderfull front seal (all "new assembly") slug PS fluid all over my Engine, frame, belts, wall, floor, ceiling, and me! Luckly it did not get in my eyes!
Hx16457 is offline   Reply With Quote
