09-25-2012, 02:24 PM | #1 |
Broke an exhaust bolt, easy out?
I'm installing my new exhaust today and of course I broke one of the bolts on the manifold flange. I soaked all the bolts with PB blaster about two hours ago, the drivers side came off no problem but two of the passenger side bolts are giving me trouble, one busted and the other doesn't want to move much. I sprayed the stuck one again and have been working it back and forth. So I have a good angle so I can get a drill in the broken bolt, is an easy out going to get the stud out? Any other suggestions? The heat riser valve is still in the system, is it best to leave it or should I get rid of it? Thanks!
http://smg.photobucket.com/albums/v655/aaronhero/ |
09-25-2012, 02:31 PM | #2 |
Re: Broke an exhaust bolt, easy out?
Had a broken header bolt for a while, kept wasting gaskets... it came out a lot easier than I thought it would.. used an easy out on it....
09-25-2012, 02:48 PM | #3 |
Could you post a picture of it? Might be able to get some better suggestions. I would say if you can get a good angle on it, drill it stay as centered as possible. Use a twisted style of easy out. The squared style, in my opinion, suck.
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
09-25-2012, 02:48 PM | #4 |
Also, when you drill it. Use a reverse drill bit, sometimes they come right out with those.
09-25-2012, 03:03 PM | #5 | |
09-25-2012, 03:15 PM | #6 |
good luck... i see you said its below the surface........ was going to say TORCH.. but.....
09-25-2012, 03:20 PM | #7 | |
09-25-2012, 05:32 PM | #8 |
I got them out, I had to drill out the broken studs and used a 3/8" tap to cut the thin layer of remaining stud out of the threads. I got the new studs in and they tightened up just fine. Now all I have to do is decide if beer would be appropriate at this point? Hmm? Yep! I think beer will most definately make the rest of the installation move right along!
09-25-2012, 05:41 PM | #9 |
Yes beer is appropriate now!
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
09-25-2012, 05:48 PM | #10 |
Thanks for the confirmation on the intake of beer! I was a little hesitant but with your blessings I just cracked open an ice cold Pacifico. Tequila goes good with Pacifico, nah! I better hold off on the Patron until after I go for a test drive!
09-25-2012, 06:19 PM | #11 |
Ha!, I just cracked open an ice cold Stella. Cheers....
09-27-2012, 12:19 PM | #12 |
sounds like tis time to celebrate.... congrats !
09-27-2012, 01:02 PM | #13 | |
__________________ Rob '72 Chevy C-10 - 350-5.7/TH350/PS/PB/AC Build Thread - http://67-72chevytrucks.com/vboard/s...87#post5503187 Semper Fi and Gig'em Aggies! |
