Scott's 63-87 Bolt in IFS....NOW WITH C-10 spindles ;)
![]() ![]() ![]() ![]() ![]() 63-87 Chevy/GMC truck with C-10 spindles: Retail price $3745.00 ...We have a nice DISCOUNT PRICE FOR MEMBERS ONLY P/M FOR PRICES!!!!! Modeled after our standard 63-87 bolt in IFS, this option allows you to finally run a full size C-10 spindle. These are available complete; with or without brakes.The year of the c-10 spindal is a 73-87 only.The ball joints are a 73-87 only Like all Scott’s IFS systems, each unit will be built to spec, individually for each customer. This allows us to “fine-tune” the suspension. For those looking to have a tight handling coilover suspension we can set it up to be fully tunable and adjustable to get that track handling on the weekends, and comfortable ride for everyday use. If laying low is your style, we can set you up to run up to a 31” tall tire and still lay frame, while maintaining superior driveability over our competitors. A Scott’s 63-87 bolt-in Superslam IFS gets nearly 11” of total travel! As always, these units are 100% TIG welded and come with Scott’s famous lifetime guarantee. Included: ● One-piece style crossmember (2”x4”-3/16” wall square tubing) ● 1-1/8”x1/4” wall tubular upper control arms (D.O.M. seamless tubing) ● CNC machined billet adjustable upper rod-ends. ● 4 degrees of built in anti-dive ● 7 degrees of caster built into the upper a-arms ● Billet adjustable coilovers or SlamBags and KYB shocks ● 73-87 CPP drop spindle ● 73-87 upper and lower ball joints ● Rack and pinion steering ● Custom 1” sway bar and hardware ● 3” overall narrowed track ● Inner frame support ● Motor mounts welded in place (when purchased) Options available: ● New power rack & pinion with lifetime warranty ● 12”-14” CPP or Wilwood brakes with all available bolt patterns ● Polished stainless steel control arms ● Torsion style sway bar ● Powder coating Last edited by Scottshotrods; 09-25-2012 at 06:24 PM. Reason: add |
Truck and auto performance nut
Re: Scott's 63-87 Bolt in IFS....NOW WITH C-10 spindles ;)
Thats awesome looking. Will this be offered in a coil over as well?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
We will be in Texas next week for the Goodguys show.If anybody is coming to the show come on by our Booth and check it out.You cannot miss us we will have a 30x100 ft booth there.
Justin |
Here's a coilover with our standard sway bar. Stand by for images with the torsion style sway bar.
Jeff Savaglio Scott's Hotrods Oxnard CA 93030 |
Images of our SuperSlam with torsion bar style sway bar.
I would really like to see one of these actually installed. I never seen any completed trucks with the old system either.
Go under the suspension link on this site.Go to Scotts hotrods bolt in on the front page under suspension.There is a red short bed step side 65 with our bolt in ifs there.You can go under the racing and drag racing link on this site.There is a 67 there with a durmax running low 9 in the 1/4 mile.The truck is weighing in at over 5500 lbs.This truck has our bolt in with coil-overs.We are finishing up 67 for dan42 who is a moderator on this site.This truck has all of our parts on his truck.We have several more as well.You can call us or e-mail us and we will send you over many pics of customers trucks with our kits.Let us know
Justin@scottshotrods.com 805 485-0382 Posted via Mobile Device |
Always a work in progress
Do you know the weight difference from stock(85 c10)?
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
#13 |
We are at SEMA this week stop on by Booth number 23280 take a looks first hand at out c-10 bolt in ifs.
Next show after SEMA for us will be Scottsdale AZ we have huge booth outside this is the Goodguys show.We will have alot of new stuff to show you all. Justin |
#14 |
Active Member
![]() Join Date: Oct 2006
Are you going to be selling your weld in step notches at Goodguys in AZ?
#15 |
Yes we will have a few sets there
#16 |
Active Member
Are you going to be offering any deals on your products at the show?
#17 |
Show deals for sure
#18 |
Active Member
Sounds good! I will def. be stopping by the booth.
