Old 09-25-2012, 06:01 PM   #1
Scottshotrods
Scott's 63-87 Bolt in IFS....NOW WITH C-10 spindles ;)
63-87 Chevy/GMC truck with C-10 spindles: Retail price $3745.00... WE HAVE A NICE DISCOUNT FOR MEMBERS ONLY P/M FOR PRICING
Modeled after our standard 63-87 bolt in IFS, this option allows you to finally run a full size C-10 spindle. These are available complete; with or without brakes.Spindals we use are a 73-87 and ball joints are a 73-87
Like all Scott’s IFS systems, each unit will be built to spec, individually for each customer. This allows us to “fine-tune” the suspension. For those looking to have a tight handling coilover suspension we can set it up to be fully tunable and adjustable to get that track handling on the weekends, and comfortable ride for everyday use. If laying low is your style, we can set you up to run up to a 31” tall tire and still lay frame, while maintaining superior driveability over our competitors. A Scott’s 63-87 bolt-in Superslam IFS gets nearly 11” of total travel! As always, these units are 100% TIG welded and come with Scott’s famous lifetime guarantee.
Included:
● One-piece style crossmember (2”x4”-3/16” wall square tubing)
● 1-1/8”x1/4” wall tubular upper control arms (D.O.M. seamless tubing)
● CNC machined billet adjustable upper rod-ends.
● 4 degrees of built in anti-dive
● 7 degrees of caster built into the upper a-arms
● Billet adjustable coilovers or SlamBags and KYB shocks
● 73-87 CPP drop spindle
● 73-87 upper and lower ball joints
● Rack and pinion steering ( NEW POWER RACK )
● Custom 1” sway bar and hardware
● 3” overall narrowed track
● Inner frame support
● Motor mounts welded in place (when purchased)
Options available:
● New power rack & pinion with lifetime warranty
● 12”-14” CPP or Wilwood brakes with all available bolt patterns
● Polished stainless steel control arms
● Torsion style sway bar
Powder coating
Scottshotrods is offline   Reply With Quote
Old 09-25-2012, 09:32 PM   #2
jmedero
jmedero's Avatar
Re: Scott's 63-87 Bolt in IFS....NOW WITH C-10 spindles ;)
Holly smokes you released it!!! It's sooo sexy. Some 14 inch wilwoods on there or the Cpp big brake kit.... Nice looking kit man.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 09-26-2012, 10:01 AM   #3
Scottshotrods
For anybody who wants to run a Big brake kit from CPP or Wilwood this can be done with no problems.The spindal you will be getting will be a Cpp Modular spindal this will allow the caliper bracket to be able to be bolted onto the spindal.There will be a little up charge on the modular spindal.Not very much at all
We also have this frontend with Coil-overs you will have two choices to choose from
1.Alden
Or
2.Ridetech
Old 09-27-2012, 10:21 AM   #4
Custom 68
Custom 68's Avatar
once again very nice.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is online now   Reply With Quote
Old 09-27-2012, 07:20 PM   #5
Bagood
Awesome, nothing else to say......
Bagood is offline   Reply With Quote
Old 09-29-2012, 12:28 AM   #6
Scottshotrods
Next we will be at the Goodguys show at Texas motor speedway.If your coming to the show stop on buy our booth and take a look at our products first hand
Old 09-29-2012, 08:38 AM   #7
wraprail
wraprail's Avatar
Will you be at SEMA this year?
What material are your bushings?
Do you offer anything for the rear 73-87?
wraprail is offline   Reply With Quote
Old 09-29-2012, 09:02 AM   #8
jmedero
jmedero's Avatar
The first 5 visitors to your booth gets a free front end....
Picture. Lol
Old 09-29-2012, 03:28 PM   #9
Scottshotrods
Our a-arm bushings are made by Energy Suspesnion for us.They are made out of a Hyper-flex polyurethane.They work Great
We will have some frontends in Hotrod Alley Booth number 23280 Retrorack booth.Come on by and check it out and if you would like to have some more info you can call us at (805)485-0382.We will be more than glad to help you out
For the rear of the trucks we do have rear kits and at this time they are a WELD on only.
On our bolt in c-10 frontends we have several kits on the market at this time.
Justin
Old 09-29-2012, 03:34 PM   #10
Scottshotrods
Picture. Lol
Great Idea!!!!
lol
Justin
Old 09-30-2012, 12:01 PM   #11
chevyrestoguy
chevyrestoguy's Avatar
Beautiful! A first class design that bolts into the stock holes in the frame, uses C-10 spindles and available in coil-over or airride.........Speechless.
You keep raising the bar, Justin!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 09-30-2012, 01:02 PM   #12
jmedero
jmedero's Avatar
How about a bolt in rear independent susp? A bolt in set up with a notch kit..... Just saying
Old 09-30-2012, 05:22 PM   #13
Scottshotrods
Very soon !!!!!!
Old 09-30-2012, 08:09 PM   #14
LUCKIN-FOU
I'M NOT SCARED I HAVE A PLASMA
LUCKIN-FOU's Avatar
That is dam sexy justin
Lou Santiago
US Navy Retired/World Traveler
Car Builder/Welder/Airport Investigator
garageinsidertv.com [FORUM]
WORK IS FOR PEOPLE WHO CAN'T FISH. I GUESS I'M SCREWED BECAUSED I HATE FISHING.
LUCKIN-FOU is offline   Reply With Quote
Old 10-01-2012, 12:09 PM   #15
jephs422
If there's any question as to the ease of install, or fitment...rest assured it is second to none. A LOT of time was spent not only on the geometry, but on making sure the fitment was simple, fast to install, and allowed for use of minimal tools.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
jephs422 is offline   Reply With Quote
Old 10-01-2012, 08:45 PM   #16
Scottshotrods
Just a Reminder this weekend is the Goodguys show at Texas Motor Speedway.Stop on by a our Booth.You will be able to see a 8 sec 67 c-10 truck that runs our Bolt in ifs and you will be able to see our NEW C-10 SPINDAL BOLT IN.
Justin
Old 10-02-2012, 07:09 PM   #17
Scottshotrods
On wed of this week we will be posting up our Coil-over C-10 bolt in with a C-10 spindal.
For you all to see and check out.
Justin
Old 10-04-2012, 10:53 PM   #18
Scottshotrods
We are all set up in Texas now.If you are coming out to the show come on by our booth and say hello.
Pics are ready to be uploaded and Jeff is slammed at the shop with us at the show.Hopefully he will have some time to uploade the coil-over set up for you to see
Justin
Old 10-09-2012, 09:58 AM   #19
jephs422
Sorry for the coilover image delay...When Justin's out of the shop, well...the mice will play, LOL.
Here's a coilover with our standard sway bar. Stand by for images with the torsion style sway bar.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 10-09-2012, 11:08 AM   #20
Custom 68
Custom 68's Avatar
I like it. Looks good.
Dave
Old 10-09-2012, 06:02 PM   #21
jephs422
Images of our SuperSlam with torsion bar style sway bar.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 10-10-2012, 09:23 AM   #22
Wasted Income
Boosted Member
Wasted Income's Avatar
That swaybar looks badass.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-10-2012, 11:21 AM   #23
jephs422
It works great too
Especially for those running a super wide front rim/tire combo. Because it comes in a lot further than our standard sway bar, there is a ton more tire clearance.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 10-11-2012, 10:56 AM   #24
Scottshotrods
If you are going to SEMA this year stop on by Booth #23280 Retrorack and check out our C-10 bolt in with a Modular C-10 spindal.HUGE BRAKES and some other tricks.
We will be in HOTROD ALLEY.
Justin
Old 10-11-2012, 03:11 PM   #25
gofastnut
gofastnut's Avatar
Justin......I'm in love....with your work!
I'm thinking of doing a Rags to *****in story for my truck, so.....can you and a bunch of the other guys on here that have way cool stuff sponsor me? LOL
Otherwise, it's just a Rags to Less - Ratty story.
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
