09-25-2012, 08:03 PM | #1 |
drw to srw back to drw
so i justt got my license and am about to get my dually on the road and i was wondering if itd be cheaper to convert it to a srw since i have a extra bed and a set of wheels.i dont tow much so its not like id need the extra 2 wheels.id keep my one ton springs and d70. would it be worth it tell i can afford to straight axle it on 37s? any opinions
75 c30 silverado drw 454/th400hd d70 soon to have d60 up front 73 c20 custom deluxe sm465 14bff parts truck |
09-25-2012, 08:58 PM | #2 |
Re: drw to srw back to drw
people i need opinions
09-25-2012, 10:10 PM | #3 |
people i seriously need opinoins. i ahve a bed rear end and all. so need help
09-25-2012, 10:32 PM | #4 |
The cheapest would be to sell the extra parts you have since they are much much much more in demand than a dually bed or dually rear axle which you would have left over after the swap.
Plus the swap always has additional costs associated beyond having a bed and axle. Stuff breaks when unbolting. Brakes need to be bled, may need freshening, etc. If you're thinking gas mileage is going to drastically improve going from dually to srw then you are mistaken. Might save a fraction of a gallon per tank, if that, under the best of circumstances. If you are running SRW then you only buy 2 rear tires rather than 4 every 60-80,000 miles, again, were talking $200 every 3-5 years depending how much you drive. Convert to single rear axle if you want it, but don't do it to save money because you won't save enough for it to matter and/or be worth the cost and effort. |
09-26-2012, 03:13 AM | #5 |
if i convert it itll go back when i can afford it. i just odnt wanna buy 6 tires specailly when there 16.5s
09-26-2012, 07:54 AM | #6 |
I'd leave it dually but not for any other reason than I like 'em.
I have an '85, in the same boat. Leaving it dually, looking for a D60 for the front. Few and far between and way high priced when I find one. Might be a while! |
09-26-2012, 09:25 AM | #7 |
If you aren't wanting to buy 16.5" tires, just look on your local CL or ebay for a set of 16 inch dually wheels and tires. If you are careful you can come out with a decent set of tires and wheels for the same cost of a set of new tires.
09-26-2012, 11:47 AM | #8 |
I'd just leave it dually, don't go through the hassle of converting it twice.
09-26-2012, 12:16 PM | #9 |
^ what wyattglock said for sure. Plenty of 16" dually rims show up on craiglist all the time and I can have 'em sandblasted and powder coated for about $20/rim. 16" tires are fairly common, too. The good load rated ones for 1-tons aren't snatched up nearly as fast as the 17" and up, makes for better deals.
09-26-2012, 12:36 PM | #10 |
I would stick with the dually myself, like others have said get some used 16" rims.
Couldn't you just run a single dually rim on each side in the back (just the outboard wheel and tire) to save on having to buy 6 tires. Might look a little odd though.
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
09-26-2012, 05:21 PM | #11 |
the other thing is i love the look of these trucks with about 6-8" lift with old school welds 16.5x14s or 12 wides with 33-35"x14.50 boggers or tsls.
but then again i wanna straight axle it with a 8-10" lift with 37x12.50 millatary tires with a 12v cummins and a 8" stack
09-26-2012, 07:20 PM | #12 |
i could run a single wheel since i have a set but then id have dually fender still and i have a extra srw bed in ok shape so i could slap it on
09-26-2012, 07:24 PM | #13 |
what would look better either way its getting converted to 4x4.
either 8-10" lift with 37x12.50 millatary tires kept a dually or convert to srw lifted 6-8" with 16.5x14 welds with 33x14.50 or 35x15.50 boggers or tsls
