Old 09-25-2012, 08:26 PM   #1
weider1717
ready to order lift, now what width wheels and backspacing?
going with either the 2" or 3" tuff country suspension lift for my 87. The wheel width will I guess determine if I need the 2" or the 3" lift.
the stock rallys are 8" and i thought about putting the 33's on those but I really like the mickey thompson classic II's and if I get them I am thinking about getting them 10" wide for a beefy look.
question is would 33x12.50's on a 10" wheel rub with a 2" lift? if so would it even with a 3" lift?
the 3" might be safer but I'm not too big of a fan of a lot of fender gap so still kinda leaning towards the 2" but if 10" wheels would rub I will do 3" because iMO the 10" wheels look better than the 8's.
thoughts?
weider1717 is offline   Reply With Quote
Old 09-25-2012, 08:57 PM   #2
88Jimmy4x4
88Jimmy4x4's Avatar
Re: ready to order lift, now what width wheels and backspacing?
dont get a wheel with same tread width of tire, looks silly imo and not good for treadwear...get 15x8's with 4" backspace (0 offset) or close to it
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 09-25-2012, 10:10 PM   #3
weider1717
The tires will be 12.5" and the wheels 10" but are you saying thats too close together still? I noticed the mickey thompsons also come in a 8.5" width would you suggest that as somewhat of a happy medium?
also the stockers are 15" would it be silly to move up to a 16" or do people typically stick with 15" rims on these trucks? I wonder what size has more tire options.
Old 09-26-2012, 07:07 AM   #4
88Jimmy4x4
88Jimmy4x4's Avatar
12.5" is not the tread width
what tires are you looking at?
1991 GMC Jimmy 4x4
Old 09-26-2012, 07:09 AM   #5
Your41Plague12
Your41Plague12's Avatar
I'd go with the 2" lift with factory rally wheels. I love the look of "stock but mean."
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is online now   Reply With Quote
Old 09-26-2012, 08:08 AM   #6
ymerej71
ymerej71's Avatar
With a 2-3" lift I'd go with the stock (or aftermarket) 15"x8" wheels with the 33"x12.50" tires. I've always ran 33x12.50 on 8" wide wheels on my jeep for years... It's a perfect size / width combination. I think they just looked a little stretched on a 10" wide wheel. Also, if you stick with a 15" wheel you can save a little $ on tires... Generally the same size tire will be cheaper in a 15" diameter than some of the newer more popular larger wheel diameters (16"-20"+).
ymerej71 is offline   Reply With Quote
Old 09-26-2012, 11:27 AM   #7
Ski-me
Ski-me's Avatar
I agree, the 15x8's will look great with 33x12.5's. I ran 15x9's and still looked good but saw a lot of 15x10's and in my opinion.....too much rim exposed and looks goofy to me.
Suburban - 33x12.5 bfg's on 15x8 stock wheels. 1.5" add-a-leaf lift.
Blazer - 33x12.5 or 32.11.5 bfg's on 15x9 Progressive wheels. Stock height.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 09-26-2012, 11:34 AM   #8
Ski-me
Ski-me's Avatar
and now today.....
2.5" BDS lift, 35x12.5 with, I think, 15x10's.
The larger tires are actually 37" tires and the 2.5" lift when I got the truck back....... It rubbed all the time!!
- Jeff
Old 09-26-2012, 12:46 PM   #9
weider1717
Originally Posted by Ski-me View Post
and now today.....
that pic with the bfg mud terrains..thats looks great thats just a 2.5" lift and the bfg's are 35's? looks sweet! does it rub bad?
Old 09-26-2012, 12:51 PM   #10
weider1717
I agree a stock look and mean is what I like too. Would a 2" clear the 33's completely? even with 10" wheels if I ever went that route.
Old 09-26-2012, 01:05 PM   #11
88Jimmy4x4
88Jimmy4x4's Avatar
are you going to offroad with this or strictly street driving?
1991 GMC Jimmy 4x4
Old 09-26-2012, 01:55 PM   #12
zirk
zirk's Avatar
That burb is the look I want with my truck, nice
Chevy runs in my blood
zirk is offline   Reply With Quote
Old 09-26-2012, 04:41 PM   #13
Ski-me
Ski-me's Avatar
Basically, I wanted the 1/2 ton truck to stand like a 3/4 ton. So 1.5" add-a-leaf up front was the looks I was going after. I think I experimented with the back and might of ended up with 2" in the back if accounting for sagging rear springs......
Minimal rubbing with the 33" on the suburban
Minimal rubbing with the 35" on the Blazer
It does rub just a little on the rear, inner corner when I turn and hit a large bump or driveway with a little speed. Take it more gently (keep the suspension from moving around) and I get no rubbing. On the blazer, the inner lip is hammered in just a bit but nothing out on the fender. Still looks good.
37"....rubbed all the time!
- Jeff
Old 09-26-2012, 04:48 PM   #14
Ski-me
Ski-me's Avatar
If I did it over again, you could get some zero rate springs up front and possibly out back to get a 1" lift. I will say, the 1.5" add-a-leaf was less than perfect.
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
- Jeff
Old 09-26-2012, 07:42 PM   #15
88Jimmy4x4
88Jimmy4x4's Avatar
zero rates are good to add a lift to new spring lifts, but adding them to an old sagging leaf pack with worn out cracked bushings is not the way to go imo.
1991 GMC Jimmy 4x4
Old 09-26-2012, 07:43 PM   #16
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Depends on what your going to be using the truck for. If your going to be wheeling a lot I would go with the 3" lift. If its mainly street driven the 2" lift should be just fine. I like the 10x15 rims personally but that's me They do stick out a bit more defiantly.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 09-26-2012, 09:07 PM   #17
weider1717
looks like your k5 clears 35's fairly good with only a 2.5" if I went 3" I would have the option of 33's clearing in whatever cond and 35's clearing on the street pretty good...
ok here is what I plan to go with so far tuff country 3" all springs, mickey thompson classic ii 15X10...here is the part thats gonna make it I think..toyo 33x13.50 tires on a 10" wheel it should look nice and they're true 33" tires so def should be a big diff with them and a 3" lift.
Old 09-26-2012, 09:50 PM   #18
88Jimmy4x4
88Jimmy4x4's Avatar
sounds like a good plan (exactly what I had aside from wheel width) but I would go with 15x8 so the sidewall doesnt balloon out...just my opinion and coloradok5 general concensus
here is my 33x13.50 on 15x8 with 4.25" backspace
1991 GMC Jimmy 4x4
Old 09-27-2012, 06:49 AM   #19
weider1717
13.50's on 8" wheels? I had in my mind the wider wheel wouldn't cause the ballon look but a smaller wheel would but in your picture the tires look great on the 8" wheels.
Old 09-27-2012, 07:00 AM   #20
Your41Plague12
I'm running 38x15.50's on a 16x10". It works just fine and looks great. I'd go with an 8" wide wheel on anything 13.50 wide and smaller. 14.00 and up should get a 10-12.
Steve
Old 09-27-2012, 07:21 AM   #21
88Jimmy4x4
88Jimmy4x4's Avatar
thats not tread width thats overall width which includes sidewall....look at secs of any non metric sized tire.
for instance....a 33x12.50x15 BFG has a tread width of only 10", the section width is 12.4.
if you want 10's....go for it, Im just giving you some advice, you dont have to take it
1991 GMC Jimmy 4x4
Old 09-27-2012, 08:11 AM   #22
88Jimmy4x4
88Jimmy4x4's Avatar
Heres the 33x13.50 on 15x10's, looks like the tread width isnt as wide as you thought and Im not digging the ballon look.
1991 GMC Jimmy 4x4
Old 09-27-2012, 08:12 AM   #23
88Jimmy4x4
88Jimmy4x4's Avatar
heres the same tires 8's
1991 GMC Jimmy 4x4
Old 09-27-2012, 09:51 AM   #24
Ski-me
Ski-me's Avatar
I'd say 15 x 8's. If you already have them, mount them up and see if you like them. If you don't, you can pay more and switch.
Love the rims 88Jimmy! Sharp!
- Jeff
Old 09-27-2012, 12:30 PM   #25
weider1717
ok, I agree thanks for the advice this is why I post before I buy and also from what I read going with 12.50's on 8's I should not rub even wit hthe 2" lift.
