09-25-2012, 08:29 PM | #1 |
For those that have champion radiator. What did you do for Steam port?
Called champion today for a quote. 3 core with 14" or 16" fan relays and wiring kit, built in tranny cooler for $353.60 which is a great price compared to Entropy. This should drop right in with no mods and should suffice for the LS motor.
Question is what are you guys doing for the steam port. He told me they will not put one in and they do not come with them. ? I have a LY5 5.3 from 07 tahoe. So mine is already plumbed and i just need to hook it up to radiator, unless there is another option. Thanks |
09-25-2012, 09:24 PM | #2 |
Re: For those that have champion radiator. What did you do for Steam port?
I spliced it into the hose with an aluminum adapter drilled for a hose barb. Others have had someone tig a barb onto the aluminum radiator itself. More than one way to skin a cat...
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
09-25-2012, 10:06 PM | #3 |
Jaguars That Run (JTR) sells aluminum reducers /splices with the barbs, sight glasses, drains built in. Here's their websight http://www.jagsthatrun.com/Cooling-S...rts_Order.html
1950 Chevy 3100 Ramp Bed 1-ton http://67-72chevytrucks.com/vboard/s...d.php?t=749386 1965 Chevy Step Side 1971 Chevy Short Wide Bed http://67-72chevytrucks.com/vboard/s...d.php?t=277191 1971 Chevy Chevelle 1972 Chevrolet C-30 1 ton 2002 Winnebego Class A MH Ford E-550 Chassis V-10 2005 Dodge Ram 2500 5.9 Cummins 2008 GMC Denali 2020 Jeep Wrangler Unlimited Rubicon |
09-25-2012, 11:08 PM | #4 |
09-26-2012, 11:07 AM | #5 | ||
09-27-2012, 04:55 PM | #6 |
Update- They will add the steam barb for $50
Total comes out to $ 404.95 3 row rad. 16" fan, relay and wiring kit, built in tranny cooler. This is for a stock LY5. |
09-27-2012, 09:58 PM | #7 |
You don't have to weld in a steam port fitting, you can just use a bulkhead fitting with an o-ring. Drill a hole in the tank near the filler. You can access the nut for the fitting thru the filler hole. I have run this way for a couple of years, no problem.
TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
09-28-2012, 01:48 AM | #8 |
Is there some reason you can't just plumb it into the expansion tank?
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
09-28-2012, 09:02 AM | #9 |
It needs to be on the high pressure side of the system.
TR
10-03-2012, 01:59 AM | #10 |
Collector of Projects
Do you have a part number for this fitting? ... or at least a brand? Where did you find yours?
10-14-2012, 08:04 PM | #11 |
True Addiction
Guys,
Apologies for asking, but do all LS engines require this? Thanks
RCC |
10-14-2012, 09:07 PM | #12 |
10-14-2012, 10:14 PM | #13 |
For MCMLXIX,
Sorry for the delay. I used a standard AN-3 bulkhead fitting. I sealed it against the tank with an o-ring washer as shown in the pics. Works good. The champion core is leaking so I am switching to a Griffin made for our trucks with the LS swap. So the inlet and outlet are LS size and the steam fitting bung comes welded in. TR
10-17-2012, 09:52 PM | #14 |
True Addiction
Could someone post a picture of where the steam port attaches to the block? Thanks
RCC |
10-18-2012, 10:07 AM | #15 |
Boosted Member
I drilled and tapped my water pump and ran it there.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
10-18-2012, 10:08 PM | #16 |
BigShoe,
It is very difficult to get a picture of mine. Probably much better pic on the board somewhere but I hope this helps some. TR
10-19-2012, 12:53 PM | #17 |
Truck and auto performance nut
best shot I have of the steam tube...running from the front of one head to another (with a piece of rubber hose for vibration insulation in the middle) along the front of the valley pan... and then the barb you connect to, on one end of the tube pointing up, which has blue tape on it.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
10-21-2012, 12:48 PM | #18 |
True Addiction
Ahh, ok. Thanks guys
RCC |
10-21-2012, 01:08 PM | #19 |
glad to help!
