09-25-2012, 09:13 PM | #1 |
Rocker panel
64 short step. On the rocker panel is there supposed to be a lip to hold the door rubber? If so I believe mine has rotted away.
Thanks Larry |
09-25-2012, 10:52 PM | #2 |
1961 crewcab
Re: Rocker panel
yes, they are almost always gone on the drivers side, but the lip runs right under the outside edge of the sill plate .
if/when you get a replacement rocker the lip will be on there
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
09-26-2012, 09:12 AM | #3 |
Re: Rocker panel
Thanks Jon. The pictures are a great help. Where did you purchase yours?
Larry |
09-26-2012, 11:41 AM | #4 |
meowMEOWmeowMEOW
Re: Rocker panel
When I pulled me old weather seal, the metal lip came up off the floor with it, boy was that rusty.
09-26-2012, 04:56 PM | #5 |
Re: Rocker panel
Where did you buy the rocker panel from. The fit looks pretty good.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
09-26-2012, 05:25 PM | #6 |
Re: Rocker panel
I have completed the same rocker re-new project and they fit on fine as well. I purchased them from LMC, (she's a 65')
Posted via Mobile Device |
09-26-2012, 09:09 PM | #7 |
Re: Rocker panel
Good to know.
Thanks Larry Posted via Mobile Device |
09-27-2012, 08:58 AM | #8 |
Re: Rocker panel
When you guys replaced the rockers, did you use a spot weld cutter to remove the old ones? If so, do you remember about how many there are to cut?
09-27-2012, 09:11 AM | #9 | |
Re: Rocker panel
it is handy to have if you are going to be working on one of these ron |
