Old 09-26-2012, 01:18 AM   #1
Pont406
feedback on 8" boosters
Thinking of buying a smaller booster to get more room and maybe it will help with low vacuum. Something similar to this one http://www.ebay.com/itm/221036147208...84.m1423.l2649
Did any one try one yet? How is a feedback on them? I already have power brakes but can't find a small booster by itself . I want to get some runs at Irwindale 1/8 mile and theirs shut down area design mostlly for newer vehicles. Even at 80mps somtimes it's a bicth to get off. It will be a little faster now. Thanks a lot
Pont406 is offline   Reply With Quote
Old 09-26-2012, 09:27 AM   #2
Sammy
Re: feedback on 8" boosters
I have one on my GMC. Heard before I purchased it that if you have a radical cam that the vaccum it produces would effect it's operation. I am using it with a basic stock 350 and have noticed no noticeable reduced performance. Those 8" are available individually without buying everything in a package both on E-Bay all the time. I believe CPP even sells them also. If your engine is beyond a stock configuration I would recommend contacting someone who has expertise in smaller boosters to figure what you would be satisfied with.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 09-26-2012, 09:38 AM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I'm using one on a stock 250 6 cyl.It works well.Doesn't make the brakes better but does reduce pedall pressure.It also gave me enough room to miss the induction system(carb,intake air cleaner).
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-26-2012, 08:10 PM   #4
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I don't think an 8" dual booster will do much different then an 11" single. How much vacuum pressure is your engine producing? I have an 8" dual with a 383 Stroker motor that produces 11" of vacuum. I'm not that impressed. If I were you and running this on the strip I would consider adding a vacuum can.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 09-26-2012, 08:58 PM   #5
Fitz
I use an 8" dual diaphragm booster on my 67. The engine is too wide for the stock unit and with it's fairly radical cam this motor makes only 9 in of vacuum, not the 16 or so most boosters need to function correctly so...I installed a remote vacuum pump to run the booster. Works just fine.
Fitz is offline   Reply With Quote
Old 10-11-2012, 12:51 AM   #6
Pont406
Got it in tonight and put some miles on it. At least now I have room to remove valve covers. For some reasons brake light is coming on and off but i never opened the system.
Old 10-11-2012, 09:28 AM   #7
GMCJOE
GMCJOE's Avatar
Probably cause your rod from the booster isn't seated on the piston of the MC correctly yet.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 10-12-2012, 09:04 PM   #8
Transformula
Transformula's Avatar
Pontiac engine..... Good Choice!!
T.Y.N Custom Works..... Because "Stock" Sucks!
1971 K 10 GMC Long Bed
1977 Formula T/A Frame off Resto-Mod
1995 FXDL Harley Low Rider
1985 C10 ShortWide 91 Burb front.
Transformula is offline   Reply With Quote
Old 10-12-2012, 09:08 PM   #9
Fldawg
Fldawg's Avatar
most people use the small one for clearance , if you have the room go with the 11"
Fldawg is offline   Reply With Quote
