Old 09-26-2012, 10:02 AM   #1
KJSR
KJSR's Avatar
Headlight adjustment
Does somebody have the factory specs for headlight adjustment? How many feet away to adjust, how high, etc. I have a 1964 Chevrolet C10. Thanks!
1936 Chevrolet 1/2t
1964 Chevrolet C10
1964 Chevrolet C10 (sons)
1965 Chevrolet K10 Suburban
1969 Chevrolet C10
1937 Plymouth P4
KJSR is offline   Reply With Quote
Old 09-26-2012, 10:48 AM   #2
theastronaut
theastronaut's Avatar
Re: Headlight adjustment
The low beam pattern needs to drop 3" over 25 feet. Measure from the center of your headlight to the ground, and subtract three inches. Find a level spot and park 25 feet from a wall, then mark the wall at that height with masking tape. The top of your low beam pattern needs to be just under the tape line. If you have sealed beams than the light pattern will be a "blob" of light that can make aiming more difficult- there won't be a defined line where the upper half of the low beam pattern stops off. If you have H4 headlights that are E-code, you'll have a sharp cut off on the top half of the low beam pattern that makes aiming easier.
Here's a diagram.
Here's a shot that compares the E-code pattern (left) to SAE/sealed beam pattern (right side). You can see that the E-code makes a sharper line for easier aiming, and less glare for oncoming traffic.
theastronaut is offline   Reply With Quote
Old 09-26-2012, 02:36 PM   #3
KJSR
KJSR's Avatar
Thanks for the info. That was exactly what I was looking for!
1936 Chevrolet 1/2t
1964 Chevrolet C10
1969 Chevrolet C10
1937 Plymouth P4
Old 09-26-2012, 03:43 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
And a second thank you. I like the idea of the light pattern enough that might convince me to upgrade my headlights.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 09-26-2012, 04:03 PM   #5
theastronaut
Glad to help! Here's a shot of upgraded Cibie H4 E-code headlights in my '64 VW with 80/100 watt bulbs and a home built relay harness. Very wide, very bright light on low beams with a sharp upper cut off so oncoming traffic isn't blinded. I'd stick with Cibie, Hella, or Bosch for H4 housings- they are VERY high quality and produce a very well controlled beam battern. Cheaper/no-name housings won't have as good of a beam pattern- wasting light output and producing more glare for oncoming traffic. One of the best upgrades you can do!
This is in an early VW bug with the "fish bowl" headlights- the bulb is sunk into the fender so the low beam pattern isn't as wide as it would be in a flush mount application like our trucks.
This shot shows the cut off up close against a wall, these are Hella H4's in our S10 with the same harness and bulbs.
Here's the difference between cheap H4's and quality H4's.
These were Delta Tech 7" Classic Convex housings. They're just remarketed chinese Weiseim housings- don't waste your money on these! They're better than sealed beams, but definitely not worth what they cost. Sharp cut off, but very narrow beam pattern.
Cibie Z Beam housings. Much wider and more evenly distributed light.
Old 09-26-2012, 04:20 PM   #6
CRGRS 66
CRGRS 66's Avatar
And a third thank you to the OP, and the contributors... saved this thread in my electrical thread folder for future reference!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 05-27-2013, 09:59 AM   #7
McCoyAZ
McCoyAZ's Avatar
Quick question if I may?
We installed a 4 headlight system from various parts and pieces from a variety of trucks.
Because we had to assemble the system from lots of parts the lights are pointed in all different directions and I need to know a starting point on where (how) they should be aimed to begin with.
I guess the question is.... Where (how) do you get the lights aimed more or less where they are supposed to be so you have a starting point to finish the fine tuning?
McCoyAZ is offline   Reply With Quote
Old 09-12-2014, 12:14 PM   #8
65 C20
Bringing this up for Figuarus.
65 C20 is offline   Reply With Quote
Old 09-12-2014, 03:43 PM   #9
markeb01
Senior Enthusiast
markeb01's Avatar
Perhaps this diagram from the 1960 Chevy Truck Shop Manual will prove helpful:
Just park the truck 25 feet from the measuring surface, and make sure it is on level ground. I find it easiest to block the low beam lamps when doing the high beams with either cardboard or a helper. It can also be helpful to block everything but one lamp at a time if they are really goofed up in the beginning.
