![]() Join Date: Nov 2007
frame size
So Ive been trying to find a blazer or burb 4x4. I know the blazers are on the same frame as a SWB truck. I did some quick searching and it appears the burb is on its own frame? It does not share it with a LWB truck? Is this correct?
I've found some nice burbs, but all were 2wd. |
What?
Re: frame size
Yep, burb frames are specific to the Suburban.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Re: frame size
Thanks!!!
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half ![]() 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
![]() Join Date: Apr 2005
Re: frame size
Frames are the same except for the rear body mounts (very front mounts are identical) and the rear ends of the frame. The burbs rear frame is used to mount the bumper. You can convert a truck frame, but it takes a little work.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
