Old 09-26-2012, 11:01 AM   #1
JRE
3/4 to 1/2 ton info needed
I'm buying a super clean low mileage 67 3/4 ton in a couple weeks and i'm toying with the Idea of converting it to a 1/2 ton. Could someone steer me in the right direction to some build threads. thanks in advance.
JRE is offline   Reply With Quote
Old 09-26-2012, 11:13 AM   #2
71K20chevy
71K20chevy's Avatar
Re: 3/4 to 1/2 ton info needed
Personally, I'd just leave it 3/4...
You'd have to do LOTS of work, including changing axle(s) back to 6 lug.
Like I said, I don't see the need to cut up a 3/4 ton, but that's just me.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 09-26-2012, 11:00 PM   #3
scott-wisc
scott-wisc's Avatar
I have a '71 C20 that I plan on lowering and converting to 5 lug wheels. I'm probably not going to call it a 3/4 ton or a 1/2 ton. Unless your worried about cargo capacity, who cares?
scott-wisc is offline   Reply With Quote
Old 09-26-2012, 11:11 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Check out my build thread. I went from a 3/4 to a 1/2 ton. I didn't "cut anything up" either. I swapped in an entire 1/2 ton SWB rolling chassis. If all you want to do is go from 3/4 to 1/2, swap out your rear end for a 12 bolt (6 lug or 5 lug, whatever you prefer) and it is the perfect time to convert to disk brakes in the front (again, you can do 6 lug or 5 lug here)
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
