09-26-2012, 11:15 AM | #1 |
Question about kick panel vent diaphragms
I have a 72 with ac and was wondering how the vent door works on the passenger side kick panel. Seems to me the diaphragm under the hood and diaphragm by passenger kick panel work together? I think I am missing something between the 2. I have all the vacuum lines in place. There is a hole in firewall in front of the diaphragm on passenger side right above blower motor. What goes in this hole? Pictures or info would be great!
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
09-26-2012, 11:36 AM | #2 |
Re: Question about kick panel vent diaphragms
when the inside door is open, the cowl door is closed to recirculate the air in the cab. the hole is for the antenna cable.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
09-27-2012, 03:24 PM | #3 |
I thought you meant the hole on the inside of the firewall. The hole in the firewall under the hood is for the actuator arm for the cowl flap.
09-27-2012, 03:42 PM | #4 | |
09-27-2012, 04:33 PM | #5 |
Florida Edition
If you spend about $30 for the assembly manual (all the major suppliers have them) all this will make sense to you, trust me, its money well spent.
Welcome aboard by the way!
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
09-27-2012, 04:54 PM | #6 |
Is that the same as this one?
09-27-2012, 09:38 PM | #7 |
Old member
I just happen to have u some pictures. I took them today.I will be adding more as I can.
09-28-2012, 08:41 AM | #8 |
Florida Edition
^ Exellent post. The service manual and the assembly manual are different, both are great to have.
09-28-2012, 10:00 AM | #9 | |
