Old 09-26-2012, 04:43 PM   #1
pvienneau
pvienneau's Avatar
The Leaf Spring Connectors on Frame
Hello all, my 49 frame leaf spring connectors are worn where the threads are gone and on some are oval now. Is there something to be done other then drilling out the rivits and replacing them?
Pat
pvienneau is offline   Reply With Quote
Old 09-26-2012, 07:58 PM   #2
mr48chev
mr48chev's Avatar
Re: The Leaf Spring Connectors on Frame
That's about it as far as I know. I think the ones on my frame are good if you end up needing them. All it will cost is the price of shipping but I'd have to look at them and make sure they are ok. They are either going in the someone might need them box or the scrap pile when I take them off the frame.
Old 09-27-2012, 07:11 AM   #3
pvienneau
pvienneau's Avatar
48, thanks I'll take you up on that - please let me know if they look OK and I"ll send you the shipping costs and any other incidentals you require.
Pat
Old 09-27-2012, 08:50 AM   #4
focusedontheprize
focusedontheprize's Avatar
I have one if you need it. Sandblasted and painted black. More than welcome to have it, just cover the shipping costs.
focusedontheprize is offline   Reply With Quote
Old 09-27-2012, 10:40 AM   #5
pvienneau
pvienneau's Avatar
Absolutely interested. Maybe it will fit nicely in one of those USPS "if it fits it ships medium boxes". Here is a picture of one of mine on the 49 frame. Let me know how much and how you want the $. Thanks
Pat
Old 09-30-2012, 09:10 AM   #6
dsl30263
dsl30263's Avatar
Refresh my memory, y'all. Isn't that a bushing that's worn out?
dsl30263 is offline   Reply With Quote
Old 09-30-2012, 02:37 PM   #7
mr48chev
mr48chev's Avatar
Oops I thought you were talking about the front ones. I already pulled the rear ones off and sent them to someone else on here a couple of months ago. The front ones I still have though.
Old 09-30-2012, 02:53 PM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
Thats worn beyond the bushing.
dwcsr is offline   Reply With Quote
Old 09-30-2012, 03:28 PM   #9
pvienneau
pvienneau's Avatar
48, I need the fronts too. Pat
Old 09-30-2012, 05:38 PM   #10
mr48chev
mr48chev's Avatar
They are rusty but the holes and threads look good.
Old 10-01-2012, 07:09 AM   #11
pvienneau
pvienneau's Avatar
Those look better than mine. When you remove them let me know and we'll discuss. BTW - why are they being removed and what will you do for leaf springs?
Old 10-01-2012, 09:52 AM   #12
focusedontheprize
@mr48chev: Yeah you helped me out and sent them to me. However I only needed one so I have an extra one to go.
Pat I emailed you a picture of the extra I have from mr48chev. It has been sandblasted and painted flat black. All yours, just have to cover the shipping.
Old 10-01-2012, 07:52 PM   #13
_Ogre
_Ogre's Avatar
that's what this forum is all about
shop air compressor timer
Old 10-02-2012, 10:38 AM   #14
pvienneau
pvienneau's Avatar
Thanks Focus, the $ has been deposited. This board is the best of all boards I go to.
Old 10-02-2012, 11:58 AM   #15
mr48chev
mr48chev's Avatar
I'm either running Dodge Mini van springs brackets and all or robbing the truck bars out from under my trailer. I've got some heavy duty trailer springs to take care of that if I do that. It's just a dump runner trailer anyhow made out of the frame of a 70 that I rolled 22 years ago.
Old 10-02-2012, 12:21 PM   #16
focusedontheprize
Got it.
It will be in the mail Saturday morning.
Old 01-30-2013, 04:08 PM   #17
pvienneau
pvienneau's Avatar
I have the new connector and would like to ask how you guys have connected these new ones to the frame once the old ones were ground off? I was thinking of bolts with a spot weld on the nuts but would rather do it the right way.
THanks
Pat
Old 01-30-2013, 04:20 PM   #18
dwcsr
Hollister Road Co.
dwcsr's Avatar
You should use something like this
http://www.packerfastener.com/produc...?Cat=1&Prod=11
its used with a flanged nut
Old 01-30-2013, 05:39 PM   #19
pvienneau
pvienneau's Avatar
dwcsr, should i hit it wwith a weld as well?
Old 01-30-2013, 05:58 PM   #20
mr48chev
mr48chev's Avatar
I wouldn't weld on the bracket it's self. You could hit the end of the threads with a hammer to keep the nut from ever backing off but I don't think that is a real necessity. I would try to find some that fit tight in the holes though and you may need to drill the holes out to put in a bolt that is slightly larger than the rivets were.
The smallest frame bolt in the link from dwcsr is 1/2 dia by 1-1/4 long which is too large and too long I am thinking. Ideally the smooth shank of the bolt would just go through the bracket and frame and you would use a washer on the inside of the frame to finish things off so you could tighten the nut up all the way. That would give you a connection that wouldn't move around on you.
My ongoing truck projects:
Old 01-30-2013, 06:33 PM   #21
pvienneau
pvienneau's Avatar
Old 01-30-2013, 07:17 PM   #22
OrrieG
OrrieG's Avatar
I had to replace one and just used Grade 8 fasters with washer, lock washer and double nut. G8 can take a lot of torque, they are stronger and will actually pull the bolt head thru the softer frame metal (did that when I installed my transmission support the first time).
OrrieG is offline   Reply With Quote
Old 01-31-2013, 12:41 PM   #23
pvienneau
pvienneau's Avatar
Sounds good. I'll go with that.
Old 04-08-2013, 02:17 PM   #24
pvienneau
pvienneau's Avatar
OK all, I got the 2 REAR REAR leaf spring hangers off by using a grinder with a cut wheel and cutting an X into the head of the rivet then cold chisel them off. Knocked the rivets right out with a 5lb hammer. I have one replcement from focusedontheprise. Does anyone have another rear rear hanger like the one in the picture I could purchase? The part number is 593926.
Pat
