1972 K20
![]() Join Date: Apr 2008
Newer axles on my 72 K20
Hi,
I'm just about done rebuilding everythiing on my 72 truck and I found out my front diff has a bad axle u joint on the driver side. I found a good deal on front and rear axles from a 74 chevy ff rear and lockout hub front. I was hoping the front would be a bolt in and the rear only requires moving one shock mount. Can anyone help me out with this swap? I did search before posting but didnt find anything that answered my question. I need to make a decision on the 74 axles by this weekend. Please help me I'm new to 4x4 trucks. |
Re: Newer axles on my 72 K20
Your gonna replace both front and rear when the only thing wrong with the current is a bad u-joint??
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
Why not just replace the joint or joints in the stock axle and save yourself hours of work. The 74 front is a bolt in and the rear will need spring perch and shock tabs changed.
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
#4 | |
I built it
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
1972 K20
I figured I would completely rebuild the existing front axle and may need a new axle shaft on top of the usual stuff or I could do the same for a newer axle without the cost of axle shaft. I can get the whole 74 front for 150.00 so basicly even money. The current rear has a leaky pinion seal and the rear cover is leaking. I was thinking long term if I switch to a corporate rear now parts will be easier to get. Sounds like everyone thinks I should fix what I have over putting in newer used?
Posted via Mobile Device Posted via Mobile Device |
Not really gonna gain much by swapping to newer axles. I think the only thing that is different between the front two is the u-joint size. The Eaton rear that is in your truck now is the father of the corporate 14ff in the 74. I think breaks are the same, so shouldn't be hard to get parts.
Actually,the HO52 is a corporate rear. People call them Eatons,I guess,because the differential is Eaton. Enough splitting hairs. I'd buy the '74 stuff for later on down the road,or just to snatch upon a fairly sought after and nit so easy to find front axle. Switching to 14-bolt is a matter of convenience for service parts on down the road,so snatch that,too. But,I'd do the simple on repairs what you have and keep that puppy original for as long as you can,maybe forever. Maybe one day if and when something major(and hard to find) breaks,you'll have a backup plan. That '74 front end will keep the big hub appearance so as to not scream out,"I am a later replacement axle!"
1972 K20
Special K you got me thinking about how others would perceive my truck with newer axles. Would you value a mostly stock frame off restored truck higher with original axles over one with properly installed newer axles? I'm not planning on selling anytime soon but was curious about resale or desirability of a truck based on updated axles.
#9 | |
I built it
Too many projects
I would value a mostly stock restored truck higher with original axles.
I second picking up the new ones as spares and if something major or unobtainable breaks swap them in. Otherwise fix the little issues with the stock ones. (Full disclosure: I swapped a D60/11.5 AAM in my 68 K20 and if the truck were anywhere stock I would regret it.)
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
Yes,I'd value a truck with original equipment far more than replaced with newer gear. It doesn't always mean a truck was trashed or played out,but one with it's original gear says,for the most part,that it wasn't.
