![]() Join Date: May 2012
i have a huge gap about an inch wide on the bottom of the door between the fender and the door i cant figure out why i know the fenders the problem im thinkin the radiator core is higher so now it wont line up .the other side is cherry i mean lazor straight lined up can some one help me fix this gap? how ig of a gap is there supoosed to be??
Re: door gap question
It sounds like the frame horn is bent causing the radiator support to lift the fender up in front. You may be able to help the gap by raising the cab to compensate. Gaps should be even and approximately 3/16" wide.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
thank you sir
Can we see a pic of the gap?
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
How does the door to cab look as far as reveal? I would recommend checking the front cab mounts for a compressed mount and also check the core support to make sure it has the proper mount installed (height ) good luck. Cheers, Pat
Posted via Mobile Device |
![]() Join Date: Mar 2011
If you have new core support bushings-----and old cab mount bushings, that could be your prob.
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
there new all the way around ...
