Old 09-26-2012, 07:40 PM   #1
jqbass66
Question change frames help
can you put 1966 c10 on a 74 frame or is there a better change
jqbass66 is offline   Reply With Quote
Old 09-26-2012, 08:37 PM   #2
rcbildr
rcbildr's Avatar
Re: change frames help
It's best to keep the original frame.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 09-27-2012, 01:21 AM   #3
Captainfab
60-66 Nut
Been there done that and I always recommend against it if at all possible for a 2wd application. It's not a simple swap, and requires a good bit of fabrication. Here is a thread I started showing the results of the one I did years ago.
http://www.67-72chevytrucks.com/vboa...d.php?t=481023
Aside from the appearance, you have the legal aspect of the frame swap in your state. Here in Idaho, you run the risk of having your vehicle confiscated if you get caught changing bodies and frames, and not following the guidelines of the motor vehicle laws.
Unless your original frame is completely junk, I would suggest just changing the front suspension and possibly the rear end to the '71-'87 components.
Old 09-27-2012, 03:39 AM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Just roll the newer stuff under the 66 frame.
66 C20 Service Truck:
Old 09-28-2012, 10:12 AM   #5
jqbass66
Thanks for the help
