Interior Cab Light
Can someone tell me how to remove the interior cab light so it can be replaced? The 4 pound hammer leaves too many scratches. Thanks, TF
treefrog
The lens has a couple of tabs holding it on. You might try a small pry device on this, or a slight squezze with your hand (careful they get very brittle with age) then once the lens is off you got a couple of screws that hold the bezel to the cab. If you are replaceing the wiring along with the bezel be sure you tie the new wireing harness to the old one before you remove it from cab and pull the new through the cab with the old wireing harness. Have fun
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
![]() Join Date: Oct 2001
No offence but the housen isnt held in with screws it's 2 small tabs on each side of the bulb area,one you litely lift up and the other you litely push down,but be very carefull and if your replacing the wiring you should desconnect your battery to perfent a spark or short! hey Treefrog are you going to Bristol Super Chevy? Maybe I'll see ya there!
Things happen for a reason! |
