Old 09-26-2012, 08:05 PM   #1
rkintn_68
rkintn_68's Avatar
Shackle bushings ? GMC 72 K1500
How often do the shackle bushings wear out ??? Do they have a lot
to do with handleing ? Is it a good idea to update with these?
1971-1987 GMC Truck 4wd 1/2, 3/4 and 1 ton - FRONT Spring Eye & Shackle Bushing Kit - Prothane # 7-1007
Quote ( from parts store ) (Original equipment rubber bushings deteriorate quickly and give less than ideal performance. Prothane # 7-1007-SALE polyurethane bushings are designed to last up to 3 times longer than standard rubber bushings and will typical improve handling and performance. Replace factory leaf spring and shackle bushings with GMC Truck polyurethane leaf spring (and or) shackle bushings to help improve handling and ride quality)
My truck has a lot of sway and play in steering just replaced power steering
box , did not make much difference ... at 40 mph it kinda scary ...
rkintn_68 is offline   Reply With Quote
