Old 09-26-2012, 09:47 PM   #1
mookiex4
Question Timing Position 305 V6
My GMC Truck has the 305 V6 and it acts as if it is way out of time. I am atleast down to that. Along with loss of power and backfiring through the Carb, I am assuming the Timing is retarded.
When looking at the Harmonic Balancer the Marks are hard to see. I think it looks like I have listed below but have a hard time telling.
_______________ TDC
_______________
_______________ 10
I am assuming the Line without the Number is 5 degrees. I have had trouble finding what the timing setting is supposed to be. One site mentions it may be 5 degrees of TDC. If this is the case should the 5 degree line be flashing on the TDC stationary pin on the engine?
Thanks for any help you can provide.
Regards,
Mark
mookiex4 is offline   Reply With Quote
Old 09-26-2012, 10:19 PM   #2
wc63
wc63's Avatar
Re: Timing Position 305 V6
I have had a similar issue with my 63 and 66 v6s. they both turned out to be the points. got new plugs and wires along with the points and set the gap at .019 i believe. ran real smooth after that. thats just my suggestion. i havent really messed with the timing much. i have heard some stories of the timing chain jumping and creating a nightmare for the person trying to find the bug, so keep that in mind as well. hope this helps. im sure someone will chime in with some more relavant info. good luck.
wc63 is offline   Reply With Quote
Old 09-26-2012, 10:50 PM   #3
mookiex4
Smile Re: Timing Position 305 V6
Thanks for the reply to my post. I actually have done a full tune up with points and am down to the timing. I was just trying to get some timing info. How's Mesa these days. I lived in phoenix for 7 years. As a matter of fact the 65 GMC that I own and am the 3rd owner of is from Phoenix. Have a great evening.
Old 09-27-2012, 01:13 AM   #4
wc63
wc63's Avatar
its not bad out here. if you dont mind the heat. its still in the 90s, but cooling down. its alot cheaper than cali though. i dont think ill go back unless im making 70grand at least. im far from that...good luck with the timing. try joining jolly's mailing list at 60-66gmcguy.com. i often post there when its a gmc v6 specific question. theres some die hards there. you should be able to an answer
Old 09-27-2012, 10:34 AM   #5
newbe351
I'm pretty sure timing is 7.5 degrees. I ran my 351E a 10 degrees and it ran OK but I had some upgrades. Jollie's site can answer your question for sure....
http://www.6066gmcguy.org/
newbe351 is offline   Reply With Quote
Old 09-27-2012, 01:16 PM   #6
HEI451
timing specification for the 305 V6 is such:
Standard transmission: 2.5 degrees BTDC@idle
Automatic transmission: 7.5 degrees BTDC@idle
Both specs are set with the vacuum advance line disconnected from the distributor, and plugged.
So, stick, pointer between center and 0 (TDC) line, auto, pointer between 5 degree and 10 degree line.
HEI451 is offline   Reply With Quote
Old 09-27-2012, 02:59 PM   #7
HEI451
Neglected to add
Point gap from manufacturer should be .016 (.018 works better).
Dwell specification is between 28 and 35 degrees (I shoot for 32 degrees).
Old 01-02-2022, 06:33 PM   #8
AngryPirate
AngryPirate's Avatar
yikes!
My 305 v6 will only run reasonably well at 30 degrees from BTDC on my crank pulley. Anything else is a bunch of misfires and stepping on the accelerator pedal pretty much stalls the engine.
I replaced the timing chain a while back when I had the engine out but I marked everything before taking the old one off.
TBH, the engine never has run 'well' just 'well enough', so who knows, perhaps the previous chain had skipped or was set wrong?
The distributor vacuum isn't currently plugged, but I don't imagine that would make a 27.5 degree difference (It's a manual trans).
Thoughts?
AngryPirate is offline   Reply With Quote
Old 01-02-2022, 07:17 PM   #9
cwcarpenter98
cwcarpenter98's Avatar
Originally Posted by AngryPirate View Post
yikes!
Thoughts?
Could be the cam is a tooth off to the crank, or maybe the dizzy is a tooth off? Triple check firing order just in case.
I've crossed plug wires on two separate engines in my truck
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-02-2022, 07:21 PM   #10
geezer#99
geezer#99's Avatar
Distributor vacuum hooked to manifold vacuum port on the carb could easily add 27.5 degrees.
I had one that added 35 degrees.
I assume if you plug off the vac advance then it’ll barely run.
You might need to increase your initial and limit your vac advance.
Old 01-02-2022, 07:30 PM   #11
AngryPirate
None of my vacuum ports on anything are plugged or hooked up to anything.
I suppose I should plug the dist, carb and the one on the intake manifold?
Thanks for letting me know this is a possibility though.
Old 01-02-2022, 07:31 PM   #12
AngryPirate
Thanks for the reply.
I'll double check the plug wires.
The other stuff, well, I am not sure of how to easily verify those and I don't think there is one (anyone can feel free to correct me ;-) ).
Old 01-02-2022, 07:38 PM   #13
geezer#99
geezer#99's Avatar
I thought you meant the distributor pot was plugged onto the carb port.
What ports do you have open?
Any on the carb or intake should be plugged off.
Old 01-02-2022, 07:40 PM   #14
AngryPirate
They’re all open! :-)
I’ll head to the parts store and get a plug assortment.
Thanks!
Old 01-02-2022, 07:50 PM   #15
geezer#99
geezer#99's Avatar
Can you post a pic of your carb and distributor first?
Old 01-02-2022, 08:01 PM   #16
Corts60
Just here to tinker
Corts60's Avatar
Thanks!
You have some serious vacuum leaks causing your lean condition my friend. Plug up those holes and you’ll be headed in the right direction.
Old 01-03-2022, 07:02 PM   #17
slorio
slorio's Avatar
Mookie:
7.5 degrees and .019 for points according to GMC service manual for 305e v6. See attached.
Regards
Steve
New Orleans
slorio is offline   Reply With Quote
Old 01-04-2022, 12:24 AM   #18
AngryPirate
Here’s the carb, intake and dist
Old 01-04-2022, 12:33 AM   #19
geezer#99
geezer#99's Avatar
Looks like only one uncapped port on the back of the carb. It was likely used for vac advance pot on the distributor.
Is the vacuum pot good ( not ruptured)?
Have you hooked it up?
Old 01-04-2022, 12:35 AM   #20
AngryPirate
No idea about the dist pot. I’ll have to look.
I have never hooked them up.
What about the vacuum port on the intake?
Thanks for looking!
Old 01-04-2022, 12:48 AM   #21
geezer#99
geezer#99's Avatar
The one that’s hard to see.
Plug it off.
To check function of vac pot just hook a vac hose to it and apply a little lung power to it and your suction should move the arm forward. Arm is easy to see right on the side of the distributor.
