![]() Join Date: Jun 2003
I have a Ramsey REP 6000 mounted on a 2x2 receiver hitch type mount For Sale. It includes the roller fairlead, winch hand control, and 100 ft. of wire with hook. I also put a 'quick-connect' heavy duty block on the end of the power and ground leads.
I used to mount this on the back hitch of the Grand Cherokee for 'escaping' from the 'stuck', rather than going further into it. lol! It has had very light use and never failed to pull out the Grand Cherokee and it's cargo. You can use a snatch block and double the pulling rating also. The square stock under the winch mount also acts as a receiver hitch for whatever you want to plug into the mount even with the winch in place. Also, I had a 10,000 lb hook bolted to the side of the square stock so that you could run the winch hook back to the mount to double the pull power when you use the snatch block. In great condition, asking $300.00 for everything. Thanks. Last edited by 72longbed; 09-28-2012 at 12:36 PM. Reason: add pictures and text. |
Re: Ramsey REP 6000 Winch on a QuickConnect Mount
Would like to see some pics. if possible.
You got it ... I'll take some in the a.m.
Thanks. |
![]() Join Date: Aug 2003
I'll get in line. How much shipped to 30094 or business 30012?
Posted via Mobile Device |
I'll get a weight on it and then a quote from Greyhound. They are the cheapest way to ship heavy items.
I'll be back to you. What's the zip of the nearest Greyhound station that accepts freight down your way? 72 |
Thank you for the pics, i will pass at this time.
Uncle,
shipping to 30012 is 85.00. It weighs 85 lbs. but they charge the same rate for close to 100 lb. Let me know. You are # 1 right now. Thanks. 72longbed |
If you can give me till Monday aft noon I will check with my boss. We have a FedEx account. Give me your zip, box dimension. I have weight. If u can't wait that's fine.you did put30012 as business correct?
Ok uncle,
the reason I use Greyhound is that they don't require a box. If the item is easily moved and carried as is, then it can be shipped as is. You really can't break anything on this beast. It doesn't matter with Greyhound,'business or residential', because you pick up the package at the station. If I build a box around it, the weight will go up quite a bit. My zip is 19525. Will FedEx pick up at my house? Whatever you want to do ... if you arrange shipping, I'll do my best to accomodate you. Thanks. Last edited by 72longbed; 09-28-2012 at 05:47 PM. |
Size is 24" long x 10" deep x 7" high, with an 8" tail sticking out the back. Without a box.
See if they will take it as it is. Thanks. 72 |
Gotta be boxed and not much cheaper so I'm gonna pass also. Thanks for waitin on me.
Will be on eBay tonight. Fresh touch-up on the paint. Total package deal 385.00 shipping included.
No more 'tire-kickers'. |
#13 |
pics of the hand control and leads?
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
#14 |
Leads are the power and ground shown in the pictures with the Blue quick connect end. I'll have pics of the hand controller later.
Thanks. |
#15 |
I don't know if I already mentioned this .... but you can pull a trailer or a boat or anything when this winch is in place on the back of your rig. I designed the 2x2 square stock under the roller fairlead to accept a 2x2 tongue hitch ball or hook, or pintle. The 2x2 stock I used is 1/4" wall. Yeah!!
Cool, huh? 72 Mounts on front receivers too .... yeah!! Winter is coming .... where's YOUR winch?? |
#16 |
As I stated earlier in post # 12, winch and mount have been re-conditioned and listed on ebay. Can't deal with people trying to undercut other members by PM's. If anyone is for real interested in buying this package deal, you can 'Buy it Now' or bid like everybody else on eBay. Fair is fair to all. If after the auction is over, it's still available, I'll re-post it here for sale.
Thank you. 72longbed |
#17 |
Catchy title goes here..
![]() Join Date: Mar 2002
Since it is listed on EBAY at this time, the thread is closed to avoid confusion. Feel free to relist it, if it is available at a later date.
