Old 09-27-2012, 04:43 PM   #1
scott-wisc
scott-wisc's Avatar
'69 Camaro gas tank
Here are some photos of my gas tank relocation project. I know that ground clearance has been a topic of discussion. The distance from the bottom of the bumper to the lowest part of the tank is 7.5 inches. The suspension has not been lowered yet so I don't know what the ground clearance will be.
scott-wisc is offline   Reply With Quote
Old 09-27-2012, 07:44 PM   #2
kevmac
kevmac's Avatar
Re: '69 Camaro gas tank
love it, sellin my blazer tank now!!!!!!
kevmac is offline   Reply With Quote
Old 09-27-2012, 11:18 PM   #3
54belair
54belair's Avatar
What size is your square tubing?
Im doing the same to mine but Ive got to fab some cab changes before I get to the tank relocation.
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 09-28-2012, 04:13 AM   #4
scott-wisc
scott-wisc's Avatar
square tubing between frame rails; 1X1
rectangle tubing spacers; 2X3
6 feet of each.
Old 09-28-2012, 05:39 AM   #5
foz
foz's Avatar
Might check this thread too. It shows install of a camaro tank as well.
http://67-72chevytrucks.com/vboard/s...d.php?t=423035
foz is offline   Reply With Quote
Old 09-28-2012, 08:57 AM   #6
54belair
54belair's Avatar
Thanks, Im familiar with Sliders' thread. Ive actually seen a few more and the spacing varies a little. Your technique and sliders are almost identical. I did notice that the filler height on yours appears to be slightly higher than sliders", using the same size tubing.
One of things that both ways work-----Ill find out the "whys" when I do mine.
Good looking job by the way, thanks for the reply.
1968 short stepside
1966 mustang
1966 chevelle ss
My Build Thread
Old 09-28-2012, 03:39 PM   #7
Leftlane
That looks nice.
I assume you added the rear sump part.
I'm wanting to do something along these lines and have looked at a few different rea tank installs.
The one thing I've noticed is that with this tank in particular, most seem to use the top flat surface as the referance in terms of mounting angle.
Is this the angle the tank gets mounted in the Camaro?
At that angle do you really have access to the whole 18 gallons of capacity, and will the sender read correct?
It almost seems that if you angle cut the 2x3 box tube narrower towards the front; you could bring the front edge of the tank upward. sort of rotate the whole thing clockwise (if viewed from the drivers side)and raise it so the filler stays in the same place.
That would really make your sump the lowest point, or get closer anyway.
That wouldn't put the filler above the tank, would it?
Looks like you could probably get the flange about parallel to the frame.
That would gain some ground clearance also.
I'm not being critical; what you've done looks great.
I'm just wondering if the tilt would work, or if i've overlooked something.
1971 C10 SWB 350/350 A/C PS PDB
Leftlane is offline   Reply With Quote
Old 09-29-2012, 05:53 AM   #8
scott-wisc
scott-wisc's Avatar
Correction- the spacers are 1 X 3 inch.
I figured now would be a good time to weld a sump in, even if I don't need it right away. When I cut the square in the license plate bracket, I added the half circle for maximum clearance. I am using the same spacer set up as Slider's, but the tank looks higher up. Not sure why, Maybe just a different brand tank?
