09-27-2012, 05:24 PM | #1 |
Catylatic converter heat sheild.
Under the truck last night trying to pull my stock cat crossmember, and I noticed that there is a cat converter heat shield that bolted to the middle and I think was held in place between the frame and the cab, but I could be wrong on that. Is there an easy way to remove it? I know it was bolted to the CM but I couldn't figure out how it was mounted to the cab orframe. I'd like to remove it to clean up under there since I don't have a cat but I gotta figure out how to get it off though
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
09-27-2012, 08:25 PM | #2 |
Re: Catylatic converter heat sheild.
I think it's attached with two or three self tapper bolts, driven from the top side of the frame rail.
If you take a flat wrench and slip it between the cab and frame you might be able to get them loose and get the shield out of there. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-28-2012, 12:29 AM | #3 | |
Thanks Keith, I'll see what I can do.
09-28-2012, 02:07 AM | #4 |
Used a Sawzall on mine. The best force is brute force lol
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
