09-27-2012, 09:52 PM | #1 |
question about 6" drop in back
hey guys i have a 3" lowering spring and a 2" block in the back now but its not low enough so i am going to but a 4" spring in there do i need to relocate the shocks if i do that??????
the front is 2 1/2 drop spined and a 1" drop spring as well |
09-27-2012, 10:05 PM | #2 |
Re: question about 6" drop in back
the ride would b noticablly better with the shocks relocated to the more vertical position
09-27-2012, 10:10 PM | #3 |
ok but its not a must right ??
09-27-2012, 10:10 PM | #4 |
67-72 parts collector,…
Just buy a 6" drop spring.
09-27-2012, 10:13 PM | #5 |
well i was only doing that because I all ready have the 2" block in there
09-27-2012, 10:46 PM | #6 |
there is no requirement with any drop that you end up with a good comfortable ride
09-27-2012, 11:00 PM | #7 | |
If you have 15" wheels,... a 1.5" or less block would be better to eliminate scrubline issues.
09-28-2012, 12:13 AM | #8 |
BlahBlahBlah
This is true. I keep looking at my panel with four inch springs, two inch blocks, and shocks relocated. With the 15 inch wheels its not good. Too bad they dont make the burb/panel lowering springs in a 6 inch drop =(
09-28-2012, 10:52 AM | #9 |
Have you tried ECE for 6" dropped springs?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-28-2012, 12:25 PM | #10 |
Junior Member
CG-I have not found anyone who makes a specific drop spring for a burb. You just have to use a truck spring and with the extra weight I think a 4 or 5 inch would be max.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
