Old 09-27-2012, 10:17 PM   #1
'82 steppin
'82 steppin's Avatar
Chassis Reinforcement
Did anyone tried to reinforce the chassis? My truck in the paint shop and they found out the chassis up front is little bit twisted and noticed that the chassis is not the greatest design by GM and I was thinking of putting up bridge between the chassis to hold it more tighter does anyone have ideas on this?
'82 steppin is offline   Reply With Quote
Old 09-27-2012, 10:53 PM   #2
Mr. 250r
Mr. 250r's Avatar
Re: Chassis Reinforcement
2wd or 4wd, if 4wd has it been abused because that usually leads to frame problems
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 09-27-2012, 10:59 PM   #3
frog210
couldnt you like box it?
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 09-27-2012, 11:34 PM   #4
'82 steppin
No its 2wd I think its been involved in accident
If I box the frame it wont pass the inspection so any other idea's?
Old 09-28-2012, 12:16 AM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
Buy a new tube chassis or live with the redvines quality frame we have.
Otherwise box it and hope the inspectors are morons
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-28-2012, 04:27 AM   #6
79 silverado
If the frame was bent in an accident it can be pulled straight... It could be the bends it got were minor enough a previous owner chose not to bother with the expense of pulling it straight. Unless you are planning on working the truck hard or abusing it, once pulled straight it shouldn't have a problem with re-bending... I've had a frame fixed from an accident in a truck only to have it hit again, held up well enough that even though it bent a second time it was still able to be straightened back within specs again, and hasn't suffered anything ill since then...
79 silverado is offline   Reply With Quote
Old 09-28-2012, 09:47 AM   #7
'82 steppin
I will try to fabricate something that will make the chassis more stiffer
Old 09-28-2012, 11:07 AM   #8
Goldfinger
Goldfinger's Avatar
Could make a few brackets that bolt on in key areas to bring it in shape.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
