09-28-2012, 12:14 AM | #1 |
Mechanic
Anyone know a good mechanic in or around elpaso, texas
Truck is running great but has a strong hissing sound when I get on it , just sounds wierd. Broke my head for months now with no avail. Posted via Mobile Device
WITNESS Dont be like me be better than me |
09-28-2012, 05:43 AM | #2 |
Re: Mechanic
The first idea that hits me based on your descriptions makes me think you have a pinched exhaust!
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
09-28-2012, 09:09 AM | #3 |
Re: Mechanic
Sounds vacuum or induction related. Mine was doing the same thing after I first got it running. Does it do it with the air cleaner off? The first air cleaner I choose had a bar than ran across the center to hold it in place on the rod, every time I got on it I had a hissing sound. Just an idea for you to check, not sure the style of air cleaner you are running.
Have you taken carb cleaner or starter fluid and sprayed around the intake/carb/vacuum lines/brake booster to test for a vacuum leak while it's running?
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
09-28-2012, 10:00 AM | #4 |
Re: Mechanic
X's Two, or baffles in the muffler have come apart.
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
09-28-2012, 10:28 AM | #5 |
Re: Mechanic
I think I would try to isolate the sound, like pulling off the air-cleaner and see if that changes the sound any.
Crawl under it and check for smashed or cracks in your exhaust, pound on your mufflers and listen for loose internals. Ray |
09-29-2012, 04:32 AM | #6 |
Re: Mechanic
The exhausted is pitted throughout, and sounds like it has something loose inside when I hit it .
Going to get some quotes on exhaust system, hopefully this makes a difference. Let you us know, thanks for your help carnales. (bros) Posted via Mobile Device
