Old 05-28-2003, 07:05 PM   #1
allthrtl
Available for Adoption
allthrtl's Avatar
700R4 Questions...
Have a question for those who have installed a 88-92 700R4...What ALL has to be changed to install the 700R4 into an 83 C10?....I found one rebuilt for $600, but the guy said it wouldn't work because it was electrically controlled, this is at a salvage yard, so knowlege is questionable..... I'm just trying to make sure it will work before I drop $600.00.........
Michael
1983 C10 SWB 2001 Silverado SWB 1995 Corvette
allthrtl is offline   Reply With Quote
Old 05-28-2003, 08:20 PM   #2
apstguy
LED King
apstguy's Avatar
NO 700R4 is electronically controlled. NONE. They changed the name to 4L60 and it was STILL not electronically controlled. Only 4L60E (the E is the key here!) was electronically controlled. Ask which one it is because all trannys are the same, jut one with elecronics.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 05-28-2003, 08:37 PM   #3
RockHQ
ROCKET POWER!
RockHQ's Avatar
The only thing electronically controlled in a 700R4 is the torque converter lock-up clutch. The lock-up solenoid gets it's signal from the VSS, or vehicle speed sensor through the ECM.
A Finnish guy made an add-in controller that greatly improves how the TCC engages and the vehicle speed needed to engage it. It requires basic electronics knowledge to build it, but it doesn't use any exotic components at all. I can post the schematics he made here if anyone's interested. I haven't had the time to build my own one yet, but since the cost is negligible i'll do it time permitting.
-Axle
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 05-28-2003, 09:23 PM   #4
RockHQ
ROCKET POWER!
RockHQ's Avatar
I should probably add that the TC lock-up of the 700R4 can be wired so that it only requires a 12+volt wire to the transmission, a normally closed brake switch and the TCC will lock up in 4th gear only. It's done with a grounding pressure switch on the 4th gear line in the valvebody. You can wire a switch in the +12v wire to have manual control of the lock-up.
Old 05-28-2003, 11:06 PM   #5
allthrtl
allthrtl's Avatar
I guess I should also mention that the truck currently has the stock 700r4 in it now, it's fried....Will I still need to do the wiring to get the 88-92 tranny to work in the my 83??? Wouldn't the 83 already have this wiring since it came with the 700r4???\
Thanks for the help....Hoping to get this thing going this weekend...
Old 05-29-2003, 01:35 AM   #6
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
The controls will be the same. The electrical connection on the tranny will be the same too. If it isn't, that means it really is newer than 93 and is a 4L60E as someone mentioned above. If it's from a wrecking yard, how do you know it's rebuilt?
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 05-29-2003, 01:53 AM   #7
allthrtl
allthrtl's Avatar
Joe, that's my question exactly.....I would require a warranty and I would pull the pan and take a look...I don't know how to rebuild transmissions, but I can tell when something has been apart and properly cleaned up....I still have a couple of more places to call tomorrow, but so far this is the best I've found....Hoping to get something done this weekend.... Thanks for the help....
Old 05-29-2003, 02:02 AM   #8
slammedLT1
slammedLT1's Avatar
-Axle
hey can you post those or email em to me?
thanks
mike
DIGGER
1984 GMC Sierra 1500 LQ4 T56 12B Chopped 2 1/4, Dropped 6/7, Shaved, Yenko Stripes
2004.5 CCSB GMC 2500HD DMAX LLY, 6" Liftmaster, 6 Fox Resi 2.0 325/50/22" Kumho A/T on KMW's LBZ MP, 5"Ex, Bullydog GT
1996 ECSB GMC Sierra 1500 350/4L60E, FL Headers, 2450 Stall, 6" Pro Comp,3" BL, Shock Hoops, , TrXus STS 38's
slammedLT1 is offline   Reply With Quote
Old 05-29-2003, 10:33 AM   #9
RockHQ
ROCKET POWER!
RockHQ's Avatar
Here are the links to the design schematics, i can translate the finnish part of the texts if necessary.
Overall design:
http://wwwk.heltech.edu.hel.fi/ideap...itys/lohko.jpg
The first controller is designed to lock up the TCC based on vehicle speed (the desired speed can be altered by changing a single component in the PCB), and will not do anything else.
It's the TCC/VSS module on the left lower corner marked with an asterisk *.
The second controller takes into account the TPS signal and disengages the TCC to improve acceleration (at or above 30-40% of max. throttle), and also provides a 10 second delay after the brake pedal is released to re-engage the tcc (improves acceleration). It's the TCC relay module on upper right corner.
PCB design and other files for the first controller:
http://wwwk.heltech.edu.hel.fi/ideaport/kehitys/tcc.pdf
http://wwwk.heltech.edu.hel.fi/ideaport/ares/TCC.zip
PCB design and other files for the second controller:
http://wwwk.heltech.edu.hel.fi/ideaport/ares/TCC.exe
Again most of the relevant information is in english, but there are some things that will need translating in order to build either of these controllers, just ask me and i'll do that. The images found in the zip and exe files are in .wmf format. As far as i know, the designer of these controllers is Mikko Esala who should get all the credits.
