Old 05-28-2003, 07:40 PM   #1
frost89434
frost89434's Avatar
Angry what not to do with fuel cell
Well If you have a fuel cell in your truck and don't have a bed on it . Take my advise and don't let it sit in direct sunlight. I did this with mine and when I came back out it was warped really bad. Just thought I'd give everyone a heads up. JIM
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 05-28-2003, 08:14 PM   #2
chevykid1969
chevykid1969's Avatar
hey man sorry to here about that. can it still be used. I have had mine in for about two weeks and no problems....yet.
Thanks for the heads up.
chevykid1969 is offline   Reply With Quote
Old 05-28-2003, 08:24 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I also had the same thing happen when I had a fuel cell located in the bed.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-28-2003, 08:50 PM   #4
progress
Gotta luv a clean shave
Most of those are made from HDPE (high density polyethylene). This material loses about 50% of its strength once the temperature reaches 150 degrees F. Black HDPE in direct sunlight will reach this temp quickly and then it will sag if empty or there is a slight vac on it from an unvented cap. You can get it back into shape by applying a very light pressure to the tank (3 - 5 psi) and using a heat gun on the areas you want to reshape. BE VERY CAREFUL WITH GAS FUMES AND HEAT!!!!!!!
Welding while you wait...you can help if you like and it...might even save you a little as long as you don't mess things up!
We make house calls too...just like the old days!
progress is offline   Reply With Quote
Old 05-28-2003, 11:14 PM   #5
frost89434
frost89434's Avatar
(progress) thanks for the info. I'll give it a try.
Sparks, Nevada
Old 05-28-2003, 11:19 PM   #6
Smooth68
Smooth68's Avatar
You sir have balls!
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
Old 06-02-2003, 10:17 PM   #7
440 charger
will i have to worry about the fuel cell under the bed?where i live it gets to about 102 on the hot days!this is my daily driver!
440 charger is offline   Reply With Quote
Old 06-03-2003, 02:57 AM   #8
crazy longhorn
Fabricate till you "puke"
Originally posted by Smooth68
You sir have balls!
yah man!
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-03-2003, 09:17 AM   #9
67chevemall
67chevemall's Avatar
I have mine in the Bed also
It likes to change shapes alright
Always seems to go back to shape though!
Need to cover it with a bed cover!!
67chevemall is offline   Reply With Quote
Old 06-03-2003, 09:58 AM   #10
VTKidder
I take it most everyone uses the polyethelene cells when relocating? Any reasoning behind going with them versus Aluminum? Just curious. Woud like to do the same thing eventually ($$!) and just wondering what the advantages are. Thanks.
VTKidder is offline   Reply With Quote
Old 06-03-2003, 10:04 AM   #11
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Polyethylene is cheap to manufacture.
I wouldn't use the heat gun trick myself. Call me chicken.
I would leave it in the sun, then add pressure until it was straight, then cool it off quick with cold water.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 06-03-2003, 07:36 PM   #12
cruzn72
VT I used the RCI tank from Summit and love it. It is aluminum. I agree with 71GMC_3/4T the price is the main issue.
http://photos.yahoo.com/cruzn72@pacbell.net
cruzn72 is offline   Reply With Quote
Old 06-03-2003, 09:06 PM   #13
Low69CST
this post is really making me think about getting an aluminum tank.....
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-03-2003, 10:44 PM   #14
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
NO SAG HERE!
These don't go anywhere...put them up under the frame and keep the bed clean...no straps either!
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 06-04-2003, 07:00 AM   #15
VTKidder
A swap will happen eventually I'm sure. Got other priorities though. I like the ideal of aluminum for some reason. I really can't come up with a reason why, but it just seems like it would be easier to have something that will not expand and contract like plastic. This past year, we had a solid 5 days where it never got above -25F, and another solid week of 100F...a real big change in temps for the year. Who knows...the only reason I want the fuel cell in the rear is safety. God forbid I get T-boned well, the last thing I want is that tank behind me touching off, or breaking open. Being a safety issue, I have no problem forking out the extra cash. There's definitely gotta be a lot of benefits to the plastic though because a LOT of people use them. Thanks for the .02 guys....
Old 06-04-2003, 10:49 AM   #16
landon4421
Life is Good !
landon4421's Avatar
I have a Polyethylene tank, mabe I will have to look into an aluminum tank.
Frank price check please for the tank
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 06-04-2003, 11:30 AM   #17
Baradium
Binder Rep
Baradium's Avatar
I'd like to get an aux tank and keep the original, put a selector switch in... would be really nice for those long trips....
Speaking of tanks....
International had this thing about options. If you wanted it, you could pretty much get it (it used to be that if you wanted something not on the list, they'd add it and keep it on the list, that's how they ended up with over 500 models of pickup trucks).
Anyways, the travelall (think suburban) came with one tank, and you could order an aux tank. And then if you really wanted you could order another aux tank. And another aux tank. And another aux tank.
This gave you one tank between the frame rails in the back that filled from the back (I hear they actually filled from the cargo area), one saddle tank in the rear driver's side. One saddle tank on the front driver's side. One saddle tank on the front passenger side, and one saddle tank on the rear passenger side. This gave you over 100 gallons of fuel capacity... and a whole lot of gas outside your frame rails.
I think I'd want to have a diesel engine if I was going to carry that much fuel (a lot less tendency to go boom). In fact, I'd like to find a rig with that set up, drop a 7.3L diesel in (pretty much a bolt in), and put some reinforcing plates around the gas tanks. Being able to drive across the country on one fill up would be cool!
Just a little fyi for those of you who might contemplate caring.
Baradium is offline   Reply With Quote
Old 06-04-2003, 12:24 PM   #18
cheyguy
cheyguy's Avatar
I'd like to see that tank selector switch!
'71 Cheyenne Super
'80 Custom Deluxe
'75 Blazer
cheyguy is offline   Reply With Quote
Old 06-04-2003, 12:25 PM   #19
VTKidder
HOLY CRAP!!!
Old 06-04-2003, 01:06 PM   #20
67chevemall
1 pit stop all the way to Cali!
Cool cool
:p
Old 06-04-2003, 01:38 PM   #21
Baradium
Binder Rep
Baradium's Avatar
I missed by about a day an IH diesel traveler. Had two aux tanks for 50 gallons fuel capacity. The TD gives at least 20mpg with 30mpg obtained by many. It was in GA so I had to wait until I could make it down there again before I could look at it, watched the ad and talked to the seller for about a month and someone came down and bought it the day before I was scheduled to look at it.
That fuel range would have been very nice, not to mention the fuel milage.
I've figured out that if I bought a Diesel scout I'd save enough on gas alone to more than cover the insurance and registration, so within a few years it would pay for itself.
