Old 09-28-2012, 09:07 PM   #1
Steve Cole
Donor serpentine setup?
What would be a Good vehicle to be a donor for a serpentine belt setup for my 70-72 chevy 350? I don't even know if this is doable but I thought hey, a 350 Is a 350.
Steve Cole is offline   Reply With Quote
Old 09-28-2012, 09:13 PM   #2
Andy4639
Old member
Andy4639's Avatar
Wink Re: Donor serpentine setup?
The s-10 v-6 4.3 is a good choice to.
Just remember you have to get a reversable water pump for it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-28-2012, 10:34 PM   #3
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Mine's from a '90 Camero. Bolted right up with only one add'l bolt hole to tap into the pass side head. Also, an exact fit for the Vintage Air A/C compressor.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 09-28-2012, 11:28 PM   #4
67c10rustbuket
67c10rustbuket's Avatar
88-95 CK chevy trucks w/sbc or 4.3 V6, 96-98 also works vortec 350. of course the same for gen1 sbc Camaro like magwak..., firebird, caprice, buick roadmaster. lots of cheap junk yard options. Here is a pic (borrowed from "lake anna") of the 88-98 CK trucks setup, same for 305, 350, 4.3v6 88-95.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 09-28-2012, 11:35 PM   #5
bonnieclyde100
my setup came from a 1991 chevy truck . i have since added AC
bonnieclyde100 is offline   Reply With Quote
Old 09-29-2012, 07:30 AM   #6
firedog
firedog's Avatar
My serp set up is from a 4.3 v6. Do remember to get the waterpump and the alternator.
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 09-29-2012, 09:59 AM   #7
Steve Cole
Man, I had no idea there were so many options! My heads don't have any threaded holes in them for mounting. Is this going to be a problem?
Old 09-29-2012, 10:16 AM   #8
hugger6933
yes that will be problematic. I too have several sets of the serp setups to use but my 327 has no head bolt holes[in the right places of course you jokers] Also the info is not quite all fact . the 88 and part of 89 bracket will work for you but is not the same as the pretty alumiun braket that we all come to see as the norm .In 1988 and most of the model year 1989 the General used a one piece steel bracket that had another bracket bolted to it, it is similar to what we use just not as pleasing. I would stick to the 90-95 C-K truck bracketor the S-T brakekt fromthe 4.3 from model year 19881/2 to1995 as well. After 1995 the motor went to what was known as the vortec[not to be confused with the S trucks eariler vortec] and it carried a differentt bracket although it will work as well it moves the a/c compressor to the drivers side and the alt to the pass side. Jim
hugger6933 is offline   Reply With Quote
Old 09-29-2012, 11:05 AM   #9
firedog
firedog's Avatar
Yea you are going to have to find some heads with accessory holes in them, from what i have read there is not enough material in the heads to drill and tap.
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 09-29-2012, 11:28 AM   #10
Steve Cole
Hey Hugger, just so I'm clear, the 90-95 bracket will work with my undrilled heads? Or maybe the 88-89? My double hump heads have too much money in them to justify replacing them so If I can't work around this issue I guess I'll have to do without.
