Old 09-29-2012, 04:34 AM   #1
armybyrd
Corvette Wheels?
Are there any Corvette wheels that will fit my '83 stepside?
Im guessing they would have to be the 5x5 bolt pattern to work?
armybyrd is offline   Reply With Quote
Old 09-29-2012, 12:09 PM   #2
slammed427
slammed427's Avatar
Re: Corvette Wheels?
You can change your bolt pattern to 5x4.75 easily enough, but as far as offset and whatnot, I'm not sure. But a set of Z06 style wheels would look tasty on your stepper.
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 09-29-2012, 12:16 PM   #3
Pop's C-10
Pop's C-10's Avatar
No...
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 09-29-2012, 01:46 PM   #4
armybyrd
whats involved with changing the bolt pattern? The hubs or?
Old 09-29-2012, 03:08 PM   #5
Pop's C-10
Pop's C-10's Avatar
bolt pattern can be changed by redrilling tha rotors & axles/drums..but tha backspace is the bigger issues..quality spacer/adapters will have to be used.
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Old 09-29-2012, 03:14 PM   #6
74 stepside
74 stepside's Avatar
ABS brakes in Orange,CA makes a rotor in 5on4 3/4 bolt pattern. Have the rear re-drilled. Otherwise adapters. Most adapters are an inch thick. If your talkn about modern vette wheels, they have a FWD offset. Really hard to pull that off on these trucks. Best bet is to choose different wheels.
74 stepside is offline   Reply With Quote
Old 09-29-2012, 06:05 PM   #7
'79squared
'79squared's Avatar
I read some where on here also that you can get a certain year camaro front rotor that has the exact same dimensions as a square body front rotor.
1979 SWB 350/350
'79squared is offline   Reply With Quote
Old 09-29-2012, 07:40 PM   #8
INSIDIOUS '86
INSIDIOUS '86's Avatar
Are you talking about the corvette rallies?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-30-2012, 08:55 AM   #9
armybyrd
Not rallies-I was thinking about newer era wheels from the C4s and C5s.
Old 09-30-2012, 04:04 PM   #10
INSIDIOUS '86
Ah those will have to be run with large spacers/adapters like four inch thick ones
Old 09-30-2012, 04:28 PM   #11
bigd65
bigd65's Avatar
I like the old Vette rallies, I thought they were a direct fit, DAMN
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 09-30-2012, 05:27 PM   #12
INSIDIOUS '86
They are if you buy aftermarket repos. Got some in my stepsider
