09-29-2012, 12:23 PM | #1 |
Please post pics of your McGaughy's 4.5 / 6 drop with C-Notch...
I'm about to order but want to make sure if that's the look I want.
Thanks, RIZ |
09-29-2012, 12:26 PM | #2 |
67-72 parts collector,…
Re: Please post pics of your McGaughy's 4.5 / 6 drop with C-Notch...
These are ECE parts,... but the best example of a 4.5/6 drop.
(with 20's)
09-29-2012, 12:27 PM | #3 |
09-29-2012, 01:30 PM | #4 | |
Chevy runs in my blood |
09-29-2012, 01:58 PM | #5 |
BIG!
I think they are 235/75-15's. Edit: Sorry I posted the wrong year truck.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 09-29-2012 at 07:47 PM. |
09-29-2012, 07:44 PM | #6 |
Spear and magic helmet!
McGaughy's 4.5"/6" is what I have on mine. I didn't install the c-notch. Mine dropped more than advertised. Pics:
10-20-2012, 07:15 PM | #7 |
10-20-2012, 11:54 PM | #8 |
10-21-2012, 09:00 AM | #9 |
10-21-2012, 09:04 AM | #10 |
No issues yet. I cut off the factory bumpstop (which you'd need to do anyway with the c-notch) and there's a lot of room between the frame and axle tubes. I put drop shocks on the rear and it rides exactly the same as it did before. Only problem I ran into with the rear is that the truck leaned a bit so I swapped the leaf springs side to side and it's pretty close to level now.
10-21-2012, 09:28 AM | #11 |
Thanks. Good looking truck, and perfect stance. Exactly what I'm going after.
Posted via Mobile Device |
10-21-2012, 12:40 PM | #12 |
mine has a belltech 4.5/6. i never notched it just cut off the factory bump stop holders
85 swb c10 6/6 drop 83 c10 bagged and sfbd project |
10-21-2012, 04:15 PM | #13 |
02-05-2013, 04:22 PM | #14 |
Do you know the offset of those wheels??? I just ordered a set in same sizes
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
02-05-2013, 04:45 PM | #15 |
4.5/6 drop on 18's.
Sin7 = Luis 1959 Apache |
02-05-2013, 11:39 PM | #16 |
McGaughy's/flit-no notch cut bump almost off for now.
05-23-2014, 05:04 AM | #17 |
New to the community ....... Looking forward to dropping mine so i can share i as well
05-23-2014, 06:46 AM | #18 |
I installed the C-notch because I had it, and a plasma cutter makes it easy, but wasn't really necessary. There's plenty of room without it as long as you aren't hauling heavy loads.
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
05-23-2014, 06:50 AM | #19 |
Very nice! I love the '77 yellow stripe trim!
05-24-2014, 01:44 AM | #20 |
Does anyone here know how the rear spring stacks affect how much lowering happens in the rear?
05-24-2014, 01:51 AM | #21 |
05-24-2014, 02:39 AM | #22 |
The thicker the spring pack is, the more inches the truck will be lowered when installing a flip kit. For example, a flip kit is normally a 5in drop with a 1 1/2in thick spring pack. If the spring pack is 2 1/2in thick it would result in a 6in drop.
John 82 Chevy Silverado 350ci/TH350 |
05-26-2014, 12:58 AM | #23 |
Thanks for the info!!!
05-26-2014, 01:01 AM | #24 |
i was thinking thats how it would go but thanks again
John 1975 Chevrolet Silverado SWB 454/TH400 |
