SBC or BBC in 1972 K20 project vehicle?
I am getting ready to start on a 1972 Chevrolet K20 Suburban project. It has a 350cid with a TH350 automatic trans which is the originalengine/trans. I have been away from the GM camp since 1989 so I need some tutoring to reclaim my memory about GM engines and transmissions. My dad had a 1972 Chevrolet C20 Suburban with the 400 BBC with automatic which I felt sure was a TH400. My prior memory told me that SBC had the TH350 and the BBC had the TH400. I was contemplating installing a BBC with a TH400 in my K20. In the various threads I have read on the site, a lot of guys reported inadequate firewall clearance when installing a BBC and they had to move the engine forward or cut out more space on the firewall. They also said they reused the SBC motor mounts. Now my dad's 'burb had plenty of firewall clearance with his BBC. According to what I have found out, the BBC used different motor mounts than the SBC.
So to make a long story short, can you install a BBC with a TH400 in a K20 without cutting on the firewall by using the motor mounts that was used on the C20 BBC? |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
Re: SBC or BBC in 1972 K20 project vehicle?
IMO I wouldn't mess with putting in a BB. Seems like too many issues to be concerned with. Why not make it easy and put in a SB 383? Check out mine.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
#3 | |
Which 383 is yours? Is that the GM drive accessories kit or a custom kit? What transmission is going behind your 383 and what axle ratios will you be running? |
I would put in a fuel injected small block and overdrive trans. A TPI ot LT1 will bolt right in the original mounts. Keep the 700R4 auto from these and move the trans mount back. Or even better a 5.3 with 4L60E swap. No way I put a BB in todays market with fuel what it is and it's only going up. If I had one I might keep it, but if I am going to swap, LS power is the way to go! Power, economy, and reliability all in 1.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#5 | |
My suggestion is to choose the route you are going to go with motor and transmission as to what you are going to use the truck for. I choose my route cause I wanted to be more street friendly, though I am still working on getting my transmission.
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
#6 | |
For whatever reason GM has the stock small block in 4x4s sitting pretty far back under the hood compared to 2wd trucks. So far back that the simple points to HEI distributor swap is a tight fit. If I had to start over, knowing what I know now, I would build the following 4x4: I'd start with a modern (up to 1999 in pick-ups a little later in Subs) 350. It comes with the roller cam shaft. I would build it into a 383 and keep the stock, vortec heads. I would run some kind of fuel injection. TBI, aftermarket, something other than a carb. I would get a 700r4 setup with the Advanced Adapters output shaft that is made to mate up with the NP205 that came from the factory behind a th350. I would move the 383 engine cradle forward and mount the longer tranny and stock t-case to the place on the frame that GM did. Then I could use standard driveshafts. 3.73 gears in the diffs. Standard height tires. I've heard that a big block will fit with the engine moved forward to compensate for the longer 700r4. Perhaps somebody that has done that swap can weigh in here.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
If I were going to spend a lot of time and $ on an engine swap it definitely would not be a gasser. I would swap in anything diesel and my engine of choice would be a 5.9 Cummins.
If your mind is made up on sticking with a gasser then I would definitely go for the 6.0L or even the 5.3L with an overdrive. |
#8 | |
The accessory drive is made by March, and is their Revolver model. The transmission is TH350 with 4.10 rear end.
