Old 09-29-2012, 08:31 PM   #1
V3500KING
V3500KING's Avatar
4L80E swap question
I am looking to get a 4L80E that came out of a 93 one ton chevy. It is out of a 4x4 truck and it has a borg warner transfer case that comes with it. Will that trans bolt up to my NP205 tranfer case or will I have to change the tail shaft and housing? Any help would great. Thanks.
V3500KING is offline   Reply With Quote
Old 09-30-2012, 02:31 AM   #2
V3500KING
V3500KING's Avatar
Re: 4L80E swap question
bump
Old 09-30-2012, 11:56 AM   #3
bilfman
bilfman's Avatar
I just did a swap into my 79 crew. It was already mated to the 205, chevy did have a 4l80e/np205 combo in 1991. It only came in crew cabs so it is a little hard to find. I put together the basics of the swap, here it the link. Good luck..........!
http://67-72chevytrucks.com/vboard/s...d.php?t=537481
Shoot me any questions if you need.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 09-30-2012, 10:53 PM   #4
V3500KING
V3500KING's Avatar
I have read your build before and it has a lot of great info. I will be applying a lot of that info on my swap. I found out that I will be needing an adapter to use the trans that I found.
