09-29-2012, 11:48 PM | #1 |
bags bleeding tank
Just putting everything back together and thought I was good and when I hit one of my switches on my air ride it seems to drain the tank instead of just that corner.
Looking at the valves now in the picture, I see why since the bottom left line is the input from the tank, but how should these be set up? If I move the input to the right of the black valve the pressure sensor reads the tank pressure instead of bag pressure. Here is a pic of the valves. |
09-29-2012, 11:52 PM | #2 |
67-72 parts collector,…
Re: bags bleeding tank
here you go,...
09-30-2012, 07:54 PM | #3 |
Sounds like you have either opened two valves at once on the same line, or managed to place you dump before your fill valves
Posted via Mobile Device |
